Solved I am looking for wincal.exe for my win 7
Rama82
I know I might be at the wrong place, but who can help me obtain the wincal.exe I loved so much in Vista, cause it is nowhere to be found in Win 7...
Brink
Staff member
mvp
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Rama82
WinCal.exe is not the calculator but the Windows Calender... and that is no longer featured in windows 7, that is why I asked here...
Brink
Staff member
mvp
LOL, sorry I have not woken up yet. :o
Windows Calendar has been removed in Windows 7 as you noticed. Instead, you will need to dowload and install Windows Live Calendar in Windows 7. :(
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Logitech MX Master
    Lumia 1520 phone
Rama82
i know that trick, but i prefer to use as little as possible from the windows live family, except for the IM... if anyone of you has a vista at home, mind sending me the wincal.exe file?
Brink
Staff member
mvp
Rama, I have no idea if this will work since I have not tried it yet, but here is a copy of the C:\Program Files\Windows Calendar folder from a 32-bit Vista. Copy the folder into your Programs Files folder, and hopefully it will work in Windows 7.
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Logitech MX Master
    Lumia 1520 phone
Brink
Staff member
mvp
You're welcome. I'm happy to hear that it works for you. :)
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Logitech MX Master
    Lumia 1520 phone
