I Can only Access HTTPS and Other Ports, Internet Port 80 Problem
xDANx
2
:mad:Hi, I really need some help. After a short time on the internet my browser stops. I have tried IE 7 & 8 Firefox with no result. I CAN only access https sites and any other with a different port (example.com:81). I have checked for malware and even reloaded Vista. I have replaced the MS firewall with ZA Pro and still no difference. I have unchecked IPV6 as well. The only way round this is to reboot and that seems to take an age. The pc will reboot in seconds normally, that’s when you haven’t been on the internet.
Please help as this is driving me MAD.
1,823
Are you using Macafee or Symantec Internet solutions? I would disable your firewall and anti-virus. Reset IE 7 to medium. Try it.
    16GB DDR667
    SAS RAID
m3rk
16
I have the same problem after installing December windows vista's updates. I can use ym, download torrents and even play online games with no lag at all.
8
Boot into safe mode, see if you have the same problem. If you don't its software causing the problem, most likely antivirus or firewall products. Try uninstalling/disabling from startup your AV/FW products (disabling it from the system tray icon won't help most of the time). If it doesn't work in safe mode I believe there are some .dll files that need to be re-registered to fix it. You could also try running these two commands in an elevated command prompt.
netsh int ip reset log.txt
netsh winsock reset
Also, you could try disabling IPv6 (including hidden tunneling adapters) by adding this registry key -
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip6\Parameters and create (if it doesn't exist) a new Dword called "DisabledComponents" and put either 1 to disable tunneling adapters or 255 to disable IPv6 completely.
Alternatively you could also go to Device Manager, click View -> Show Hidden Devices and disable everything you don't need (isatap adapters, 6TO4 adapter, teredo tunneling adapter, etc).
xDANx
2
Hi Guys thanks for your help, I have been away for christmas (mother in-law's):cry: so I havent had time to work on my PC. I will let you know how I get on.
Thanks
