i can't update STEAM after installation - please help
8
i just bought a brand new computer with windows vista home premium and Counter Strike Source, installed it and when i run it, it starts updating and at about 25% the following message appears:
Debug Assertion Failed
Program: C:/Program Files/Steam/Steam.exe
File: /p4clients/rel_beta/Projects/Common/Misc/Win32Registry.cpp
Line: 447
bCloseRet == 0L
(Press Retry to Debug the Application - JIT debugging must be enabled)
What is JIT? How can I enable it?
A
Andy [YaYa]
"bikemastermike" <bikemastermike.2ycqd6@xxxxxx-mx.forums.net> wrote in message
news:bikemastermike.2ycqd6@xxxxxx-mx.forums.net...
> Line: 447
> bCloseRet == 0L
JIT I believe is a Java thing which Steam may use as part of it's codebase,
unless you know how to code in java, (or more specifically you know how to
Debug Code), then you can probably ignore this message.
What you have is a crash of some sort, seems like Steam is crashing, only
thing I could suggest is to go to http://www.steampowered.com and download
the latest version of the Steam Client. Run the setup, it should replace
whatever you have installed now with whatever version is on their website.
Try Steam again, see if it works.
If that fails, you could try removing the Counter Strike files and download
them again. Right Click on the entry for Counter Strike and select Delete
Local Content...
I'd only do that as a last resort, may not be the files being updated, could
be something else.
best a luck,
A.
J
joker
"Andy [YaYa]" <android8675@xxxxxx> wrote in message
news:61A3B950-23FF-4A26-9429-4340548D4819@xxxxxx
>> Line: 447
>> bCloseRet == 0L
> codebase, unless you know how to code in java, (or more specifically you
> know how to Debug Code), then you can probably ignore this message.
> download them again. Right Click on the entry for Counter Strike and
> select Delete Local Content...
> could be something else.
> best a luck,
> A.
Also make sure you have the latest version of J-Initiator installed which I
believe what JIT is referring to
joker
A
Andy [YaYa]
"joker" <skyshadow5@xxxxxx> wrote in message
news:51EDA606-0B35-4A7E-AE87-7329AF688DF1@xxxxxx
>> message news:bikemastermike.2ycqd6@xxxxxx-mx.forums.net...
>>> Line: 447
>>> bCloseRet == 0L
>> download the latest version of the Steam Client. Run the setup, it should
>> replace whatever you have installed now with whatever version is on their
>> website.
>> best a luck,
>> A.
> I believe what JIT is referring to
> joker
Where do you get that? What is it exactly?
-A.
8
well when i run Steam that message appeared all the times...
by the way i uninstalled steam and css and i got the latest version of steam at their website so i would install css separetely next cuz i got it in a cd (legal - bought in a shop lol). but now the following message appears: steam is already running. you may only run one copy of steam at a time. well i only run one...
but one time steam successfully updated, but i didnt have time to do anything else lol - i had to go out... i just saw it worked was working online... the next time i ran steam it didnt work again - the same message appeared... and its been like that ever since...
by the way - where can i find out about that java / JIT thing?
thanks
ahguang
4
thanks
hi there,
i have the same problem as u too. it keep telling me that i can only run one Steam at a time. apparently u had solved this prob, may i know how do u do it?
haiz and i also have the prob of "\p4clients\rel_beta\Projects\Common\Misc\Win32Registry.cpp"
A
Andy [YaYa]
#8
"ahguang" <ahguang.35phm3@xxxxxx-mx.forums.net> wrote in message
news:ahguang.35phm3@xxxxxx-mx.forums.net...
>> thanks
> hi there,
> how do u do it?
Steam won't run if it's already running, look for the Team icon in your
system tray, right click and choose Exit to quit out of Steam, then you can
run it again from the shortcut in your start menu.
You might try running Steam a few times as Administrator (Right click,
choose Run As Admin), that'll make sure any updates get properly installed.
Don't know what else to suggest other than to check out the forums at
steamcommunities.com
ahguang
4
#9
> hi there,
> how do u do it?
thx...but i still cant solve the problem... =(
hhheellllppp anybody....
A
Andy [YaYa]
#10
"ahguang" <ahguang.35s5g1@xxxxxx-mx.forums.net> wrote in message
news:ahguang.35s5g1@xxxxxx-mx.forums.net...
> 'Andy [YaYa Wrote:
>> ;633278']"ahguang" <ahguang.35phm3@xxxxxx-mx.forums.net> wrote in
>> message
>> news:ahguang.35phm3@xxxxxx-mx.forums.net...> > >
>> > > hi there,
>> > know
>> > > how do u do it?
>> > > "\p4clients\rel_beta\Projects\Common\Misc\Win32Registry.cpp" > >
>> your
>> you can
>> click,
>> installed.
I went to GOOGLE and entered "can only run one copy of steam", and the
second link took me to a recent forum discussion on the forums at
SteamPowered.com.
One user said this:
Had the same problem, looked around a bit and found a solution that worked
for me. Go to the steam folder and find the steam.exe file and right click
and go to properties. Click the compatibility tab and if its on (For windows
XP or anything else) turn it off then hit ok and try running. Fixed it for
me maybe it'll work 4 u.
Another post on gamespot.com:
Been Having the Same Hassle with my Steam account !!
try to start, it say's updating, then at 26% it stopped with same result as
You
I am Using Win XP, had a look at Other Forum's and came across this answer
Delete your " clientregistry.blob " in yourSteam Folder, and it worked !!!!
It still went up to 26% then hesitated, then just carried on updating to
100%
you have to sign into your Steam account again...and once you've done that
FIRE IN THE HOLE !!
Basically it sounds like from the many messages I found from Google that if
you delete your steam files and run Steam.EXE or the SteamInstaller it'll
patch with the latest Vista Happy files and you should be good to go.
Try this:
1. Reboot
2. Open the C:\Program Files\Steam folder
3. Delete all files except for Steam.EXE and do NOT delete any folders.
4. Run Steam.EXE (just double-click on it)
When steam doesn't see you have any of the system files it'll simply
If that fails, delete Steam.exe as well, then go to steampowered.com, and
click download and install steam. Run the SteamInstaller.MSI file you get to
re-install everything. Did it just now, worked just fine, and the steam you
download is probably better tested with Vista than if you install it from a
game CD.
-A.
ahguang
4
#11
SteamPowered.com.
One user said this:
You
100%
FIRE IN THE HOLE !!
Try this:
1. Reboot
game CD.
-A.
thx alot!! =) but i had found another way to solve this prob...
haha i install and updated the steam in my laptop..dan i copy the whole Steam programe file and paste it intro my desktop and amazingly it work!! means that actually Steam does not really need to be installed, it can be copied from elsewhere's computer "programme file" and it can run just as well.
to summarize, the problem with my desktop steam is that it can only update till 26%.
but after i copy the steam programme file from another com, which steam had already updated there, it can work!!
thank you so much for ur help by the way... =D
A
Andy [YaYa]
#12
"ahguang" <ahguang.362re0@xxxxxx-mx.forums.net> wrote in message
news:ahguang.362re0@xxxxxx-mx.forums.net...
> 'Andy [YaYa Wrote:
>> ;641672']"ahguang" <ahguang.35s5g1@xxxxxx-mx.forums.net> wrote in
>> message
>> news:ahguang.35s5g1@xxxxxx-mx.forums.net...> > >
>> > > hhheellllppp anybody.... > > I went to GOOGLE and entered "can only
>> SteamPowered.com.
>> One user said this:
>> worked
>> click
>> windows
>> it for
>> result as
>> You
>> answer
>> worked !!!!
>> to
>> 100%
>> that
>> FIRE IN THE HOLE !!
>> that if
>> it'll
>> Try this:
>> 1. Reboot
>> folders.
>> and
>> get to
>> steam you
>> from a
>> game CD.
>> -A.
> run just as well.
> update till 26%.
Yes it can, that's why you can delete all steam files except for Steam.exe,
run it on your system and it'll reinstall/download all the missing files. It
really is a decent application and truely designed for "Digital Delivery".
What you did is a little excessive, not everyone has a notebook lying around
or a second system, but essentially it's the same thing.
-A.
ahguang
4
#13
> run just as well.
> update till 26%.
-A.
haha icic thx =)))
K
Korak9
#14
Fixed it. I went to hard drive to steam folder, first folder under client
registry,
opened up the compatibility tab and unchecked run in compatibility mode and
it ran
fine. Good luck.
> > thanks
> hi there,
> how do u do it?
> ahguang
