I get this error> SPEECH RECOGNITION COULD NOT START BECAUSE THELANGUAGE CONFIGURATION
C
carrot parrot
Hello, i get the below error.. all my settings are correct of course...
I tried a system restore but that didnt help.... any ideas about how to
fix this? Searching on google, seems to show that many people have this
problem but no one knows how to fix it
SPEECH RECOGNITION COULD NOT START BECAUSE THE LANGUAGE CONFIGURATION IS
NOT SUPPORTED.....THE RECOGNIZER LANGUAGE MUST MATCH THE LANGUAGE OF THE
USER INTERFACE. PLEASE CHANGE THE RECOGNIZER LANGUAGE IN THE SPEECH
RECOGNITION CONTROL PANEL UNDER ADVANCED OPTIONS
Re: I get this error> SPEECH RECOGNITION COULD NOT START BECAUSE THE LANGUAGE CONFIGURATION
On Sat, 22 Aug 2009 04:24:20 +0300, carrot parrot
>NOT SUPPORTED..
>RECOGNITION CONTROL PANEL UNDER ADVANCED OPTIONS ||
C
carrot parrot
Re: I get this error> SPEECH RECOGNITION COULD NOT START BECAUSETHE LANGUAGE CONFIGURATION
>> NOT SUPPORTED..
So you are good at adding quotes. I state that all my settings are
correct. Everything about the language settings are correct. This seems
to be some bug, if you google it many people have the same exact problem
without changing anything in their language settings.
Anyone else?
M
Mark Conrad
In article <4a907e96$1@xxxxxx-privat.org>, carrot parrot
> Anyone else?
I assume you have already tried what I am going to
suggest - - -
Try temporarily setting the language to some other
language, then promptly set it back to your language.
Sometimes the computer gets confused as to its settings,
this often jars it back to the correct language.
Mark-
