I need a little help in computer system design
hello all, i just started my computer system design college class, i get the concepts of it so far but i need to make a diagram of the subsystems in a computer and in a car and i really dont understand which from which.
i was thinking in like computer parts and what they do but i just dont understand is there anyone who can help me with this?
    Custom built Desktop
    AMD Phenom II X6 1090T Black Edition 3.2Ghz
    MSI 890FXA-GD70 AM3 AMD 890FX
    8GB Adata Gaming series 2.0 DDR3 1600
    MSI Twin Frozr 5830 X2 with MSI 5850 Crossfired
    Asus 19", Acer 17"
    1400x900
    OCZ Agility 3 60gb, 500GB F3 Samsung Spin point and 5 other HDD's
    850W OCZ
    NZXT Phantom
    2 200mm fans with 6 120mm fans
    Logitec G9
    Saitek 2
    Major AMD, ATI and MSI Enthusiast.
Heyy!
Okay, I think this is what your looking for;
-RAM, Random Access Memory, Used to temporarily store files that you are using alot so that they open/load quicker.
-CPU, Central Processing Unit, The primary element for carrying out the computer's functions.
-Motherboard, Holds many of the crucial components of the system, while providing connectors for other peripherals.
-Hard disc drive/s, Features one or more rotating rigid platters on a motor-driven spindle within a metal case. Data is encoded magnetically by read/write heads that float on a cushion of air above the platters.
-Video card/s, An expansion card whose function is to generate and output images to a display. Many video cards offer added functions, such as accelerated rendering of 3D scenes and 2D graphics.
-Fan/s or cooling, Used for cooling purposes, and may refer to fans that draw cooler air into the case from the outside, expel warm air from inside. Watercooling can also be used.
-CD drive/s, Used to read and write data to CD's and DVD's.
I think it would be the same for the car, just listing the components and what they do.
Also, most of this come from Wikipedia.
Hope this helps you, and good luck!
Daniel ;)
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
thank you
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Logitec G9
    Saitek 2
No problem!
If you need any more, Just shout! ;)
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
