ICommand woes...
L
Lloyd Dupont
I tried to create a SetColor command and a ColorPicker which uses it.
There is one effect I cannot reproduce, it is tracking the CommandSource and
wether it's valid.
By that I mean if I create a MenuItem like that:
<MenuItem Header="Blue" Command="{x:Static local:MyCommands.SetColor}"
CommandParameter="{x:Static Colors.Blue}" />
It enables/disables depending on wether the currently focused element
respond to the SetColor command.
But my ColorPicker never get any CanExecute or whatever event call,
therefore I cannot update it appropriately (i.e. enable/disable) when the
focused element change.
I implemented ICommandSource, used a RoutedEvent, I never get any relevant
info....
Any idea what I could have missed?!?
L
Lloyd Dupont
found it!
it's quite tricky, I remember read about it in a blog 6 month ago but it's
nowhere in the documentation!!!
RoutedCommand.CanExecuteChanged strore the event handlers as WeakReference.
Therefore you have to hold a reference to the handlers your self if you want
your event handler to be called....
R
Radek Cerny
Well done!
I am playing in the same area and am sure to have come across this soon.
Thanks.
"Lloyd Dupont" <net.galador@ld> wrote in message
news:eX9XTzHuHHA.1672@TK2MSFTNGP06.phx.gbl...
> found it!
> WeakReference.
> want
L
Lloyd Dupont
Thanks!! :-D
Additional tip:
I was trying to get a value from the command source:
I.e. I have a color picker, I want it to be initialized to the current color
of the SetColorCommand target.
There is no way to do that!
But... little trick....
ICommand.CanExecute(object obj) take any object as argument.
I used something like:
public class CommandCanExecuteArg
object val;
public CommandCanExecuteArg(object val)
this.val = val;
public object Parameter { get { return val; } }
public object ReturnValue { get; set; }
and I pass an instance of it to CanExecute(), this way the
SetColorCommandTarget can return its current color in ReturnValue
Regards,
Lloyd Dupont
NovaMind Software
Mind Mapping at its best
www.nova-mind.com
"Radek Cerny" <radekcerny@nospam.optusnet.com.au> wrote in message
news:O8ZpNDRuHHA.3368@TK2MSFTNGP02.phx.gbl...
> Well done!
> Thanks.
>> found it!
>> it's
>> WeakReference.
>> want
