IE7 and flash player
T
TS Mathews
I've just installed Vista Home Premium--full version, clean install not an
upgrade--and something has come up which has me baffled. After installing
all my usual programs--Office 2007, Adobe Acrobat 8, Zinio Reader, Repligo,
Mobipocket and I've tried both AVG and Avast for anti virus as I thought one
of them might be the problem--but there seems to be a problem with IE7...I
go to a web site which requires flash and get the prompt that I need to
install flash player and I do. It shows that it's installed when I check
the control panel but when I re-open IE7 and go to the site, I still get the
prompt that I need to install flash player. I've tried uninstalling and
reinstalling with both of the aforementioned AV programs, with them turned
off, and have tried downloading the flash player in zipped format and
installing it with IE7 closed.
The bottom line is, I'm out of neophyte guesses as I think I've tried every
conceivable method to make it work. So, I'm posting here as there doesn't
seem to be an English IE7 specific group. I've listed all of my installed
programs just in case there's some sort of conflict with one of them. I
should mention all of these worked just fine with IE7 when I was running XP.
Any thoughts, anyone?
Thanks,
Tim
M
Mike Hall - MVP
Use the utility on this web site to uninstall Flash player. Download and
save it before running. Then install Flash player again..
http://kb.adobe.com/selfservice/viewContent.do?externalId=tn_14157
"TS Mathews" <NOSPAMtsmohio@xxxxxx> wrote in message
news:AFC54C59-0E06-4BA7-932F-F0C84FE13C6C@xxxxxx
> Repligo, Mobipocket and I've tried both AVG and Avast for anti virus as I
> thought one of them might be the problem--but there seems to be a problem
> with IE7...I go to a web site which requires flash and get the prompt that
> I need to install flash player and I do. It shows that it's installed
> when I check the control panel but when I re-open IE7 and go to the site,
> I still get the prompt that I need to install flash player. I've tried
> uninstalling and reinstalling with both of the aforementioned AV programs,
> with them turned off, and have tried downloading the flash player in
> zipped format and installing it with IE7 closed.
> every conceivable method to make it work. So, I'm posting here as there
> doesn't seem to be an English IE7 specific group. I've listed all of my
> installed programs just in case there's some sort of conflict with one of
> them. I should mention all of these worked just fine with IE7 when I was
> running XP.
> Thanks,
> Tim
T
TS Mathews
Fantastic...worked like a charm. I just wonder why I couldn't find this on
their site. I found a set of instructions regarding removing it but it was
via my control panel. Then, I found their zipped version and, as they
suggested, ran it but without any luck.
Anyway, thanks so much for the URL. As I said, it's now working like a
charm and my possible regrets over moving to Vista are somewhat lower. :-)
"Mike Hall - MVP" <mikehall@xxxxxx> wrote in message
news:eYgrp0lDIHA.5328@xxxxxx
>> an upgrade--and something has come up which has me baffled. After
>> installing all my usual programs--Office 2007, Adobe Acrobat 8, Zinio
>> Reader, Repligo, Mobipocket and I've tried both AVG and Avast for anti
>> virus as I thought one of them might be the problem--but there seems to
>> be a problem with IE7...I go to a web site which requires flash and get
>> the prompt that I need to install flash player and I do. It shows that
>> it's installed when I check the control panel but when I re-open IE7 and
>> go to the site, I still get the prompt that I need to install flash
>> player. I've tried uninstalling and reinstalling with both of the
>> aforementioned AV programs, with them turned off, and have tried
>> downloading the flash player in zipped format and installing it with IE7
>> closed.
>> running XP.
>> Thanks,
>> Tim
M
Mike Hall - MVP
Good to hear on both counts.. :-)
news:EC52BD9E-62F3-42DF-AD80-66C3D7E610B3@xxxxxx
> on their site. I found a set of instructions regarding removing it but it
> was via my control panel. Then, I found their zipped version and, as they
>>> closed.
>>> of them. I should mention all of these worked just fine with IE7 when I
>>> was running XP.
>>> Thanks,
>>> Tim
