Solved IE9 causing problems with Flash (ie YouTube)
Posts
32
Hi all.
I upgraded to IE9 via Windows Update and all went well.
But I'm having issues with watching flash videos on YouTube & Hulu using IE9 with "ActiveX Filtering" enabled. Basically the flash video will not play and instead shows a black screen that prompts you to update your flash player (see attached image). Flash player and add-ons are up to date and installed (v10.2.153.1).
Now if I disable "ActiveX Filtering," flash videos in YouTube & Hulu will play just fine. But I'm worried that disabing an important protection would leave me vulnerable to attack/infection.
What should I do to fix this problem?
    Dell XPS 420
    Q6600 Quad Core @ 2.4 GHz
    Dell XPS 420 Motherboard 0TP406
    3 GB @ 677 MHz
    ATI Radeon HD 2400 Pro 128 MB
    Integrated 7.1 Channel Audio
    Dell SP2208WFP 22" Flat Panel Display
    1289x768 32-bit (for now)
    500 GB 7200 RPM SATA
    375W
    Broadband 15Mb/s download & 5Mb/s upload
Arvinwebb
Vista Lover
New Delhi
Posts
318
Hello, Welcome to the forum.
follow these steps:
1. Uninstall The Flash Player
2. To change your security level:
Open Internet Explorer.
Choose Tools > Internet Options.
Select the Security tab.
Select Custom Level.
Find the section "ActiveX controls and plug-ins".
Set ' Download Signed ActiveX Controls' to Prompt.
Set 'Run ActiveX Controls And Plug-ins' to Enable.
Download and Install_Flash_Player.
Yo...should be good to go....
Let me know the result. Thanks
    HP dv2519tu pavillion Laptop
    1.50 GHz
    Winstron
    2.5 gig RAM
    intel onboard
    Conexant HD Smart Audio HD2
    HP Brightview Display
    1280X800
    SATA - 160 + 500 GB
    HP
    HP Laptop
    Air
    HP
    HP Laptop
    4 MB/SEC-Download, 2 MB/SEC-Upload
Posts
32
Hi Arvinwebb,
I already have the latest version of flash and it was installed and used without issue before I upgraded to IE9 (just a few minutes before in fact). Flash works fine if "ActiveX Filtering" is turned off. My security settings are already set to the settings you've suggested as well. What's the point of uninstalling and re-installing flash?
    Dell XPS 420
    3 GB @ 677 MHz
    375W
Arvinwebb
Vista Lover
New Delhi
Posts
318
    1.50 GHz
    Winstron
    2.5 gig RAM
    intel onboard
    1280X800
    SATA - 160 + 500 GB
    HP
    HP Laptop
    Air
    HP
    HP Laptop
Posts
32
Hi Arvinwebb.
Thanks for the link.
I tried as the article suggested but it didn't work as it should. I did left-click the blue circle icon and chose "Turn off ActiveX filtering" and despite the dialogue box closing with the Vista "action/wait icon," nothing changed. Meaning ActiveX filtering is enabled for all sites and no exception was made for YouTube.
    Dell XPS 420
    3 GB @ 677 MHz
    375W
Arvinwebb
Vista Lover
New Delhi
Posts
318
Hello,
This link can help you a bit. just have a look:
Troubleshoot Flash Player Problems
If then you cannot play videos, such as Youtube videos, in Internet Explorer, finally try the following methods:
  1. Use the utility at Uninstall Flash Player | Windows to uninstall your existing Flash Player if you have one installed.
  2. Install the latest version of Flash Player from Adobe Flash Player download.
Sometimes uninstalling & Reinstalling provide a better solution.
Thanks.
    1.50 GHz
    Winstron
    2.5 gig RAM
    intel onboard
    1280X800
    SATA - 160 + 500 GB
    HP
    HP Laptop
    Air
    HP
    HP Laptop
Posts
32
Good news...I've found a solution. :D
I was trying various settings in "Internet Options" in the "Advanced" tab, and when I selected "Use software rendering instead of GPU rendering*" and restarted IE9, I was able to turn on/off "ActiveX filtering" on a per-site basis by left-clicking on the blue circle icon in the address/search bar. Now I can still have "ActiveX filtering" enabled (globaly) and still watch videos on YouTube.
I then went back to the "Advaned" tab in "Internet Options" and unselected "Use software rendering instead of GPU rendering*" just for testing, but surprisingly the turn on/off "ActiveX filtering" on a per-site basis capability still remained. :huh:
I really don't know the internal mechanics of why/how toggling the GPU rendering fixed my issue, but I'm glad nonetheless. I hope this helps out anyone with similar issues.
    Dell XPS 420
    3 GB @ 677 MHz
    375W
Posts
32
#8
Arvinwebb,
Thanks for all you help, mate. :D
    Dell XPS 420
    3 GB @ 677 MHz
    375W
Posts
32
#9
This post is just so I can turn email notifications off for this thread. Sorry.
    Dell XPS 420
    3 GB @ 677 MHz
    375W
Arvinwebb
Vista Lover
New Delhi
Posts
318
#10
No worry pal. Finally i am happy to know that my posts helped you.
You are welcome anytime when you have worry and even when you dont have too.
Happy Computing. would like to see you again, not with problems but to visit here.
Thanks.
    1.50 GHz
    Winstron
    2.5 gig RAM
    intel onboard
    1280X800
    SATA - 160 + 500 GB
    HP
    HP Laptop
    Air
    HP
    HP Laptop
Patonb
Posts
2,245
#11
Could be due o your older gpu not being able to render/accelerate video.
I.E. probablyh messed up, so by toggling the setting smartened it up.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
