Ignore dead server
A
atorres
I am trying to create a script that reads the registry to a list of servers
using a text file; but some of the server on the file are dead; I would like
to know how can I create a file that reports the dead servers, and then
continue with the next server on the list.
NOTE: My scripts errors out once it gets to a dead server
Here is my sample:
$Servers = Get-Content C:\Prod\AdminScripts\PS\Trend\Trend_list.txt
$File = "C:\Prod\AdminScripts\PS\Trend\Trend-Server.log"
ForEach ($Serv in $Servers) {
$reg = [Microsoft.Win32.RegistryKey]::OpenRemoteBaseKey('LocalMachine',
$Serv)
$regKey =
$reg.OpenSubKey("SOFTWARE\\TrendMicro\\ServerProtect\\CurrentVersion")
$regKey.GetValueNames()
$Path = $regKey.GetValue('HomeDirectory')
$Output = "\\$Serv\$Path"
$Output | Out-File $File -Append
N
you could use ping...do something like:
$servers | %{$test = ping -Quiet $_.name
if (!$test) {$_.name >> C:\notresolved.txt}
elseif ($test.received -eq 0) {$_.name >> c:\unpingable.txt}
elseif ($test.received -ne 0) {$_.name >> c:\alive.txt}}
> Here is my sample:
> $Serv)
> $regKey =
O
OldDog
> > using a text file; but some of the server on the file are dead; I wouldlike
> > Here is my sample:
> > $Serv)
> >    $regKey =
> > }- Hide quoted text -
> - Show quoted text -
What if they are not dead? What if they are Linux???
Give this a try..
#<---------------- Begin
$ping = New-Object System.Net.NetworkInformation.Ping
$computerlist = Get-Content 'c:\scripts\Servers.txt'
foreach ($srv in $computerlist)
$reply = $ping.Send($srv)
if ($reply.status -eq "Success")
if ($reply.Options.ttl -le 64)
Write-Host $srv " probably is a Unix host"
Else
{ if ($reply.Options.ttl -ge 65)
Write-Host $srv " probably is a Windows host"
Else { Write-Host $srv " Does Not Ping"
#<----------------------- End Script
