Import backed up emails on external hard drive
I backed up to an external hard drive my complete laptop. Now I have a new
laptop. I need to know how to copy all my emails on my backup drive to my
new computer. using Microsoft Outlook. Western Digital drive. HELP
E
Earle Horton
"Jim" <jimpeter@xxxxxx> wrote in message
news:e7rFFa$$IHA.4528@xxxxxx
There is an Outlook-specific newsgroup and one for Office too. You may find
more Outlook-specific expertise there. This is the group for Windows Mail,
a program included with Microsoft Vista. The files you want are in some
place like
C:\Documents and Settings\{user}\Local Settings\Application
Data\Microsoft\Outlook\
The above is the XP location. In principle you can navigate to this
location on your old file system, copy the entire folder, and paste it into
the corresponding location on your new computer. The emails will be in a
file named "Outlook.pst". In Outlook 2003, right click Personal Folders,
select Properties for "Personal Folders" then press the Advanced button.
Filename in that screen will tell you where Outlook stores its data files,
the destination where you are to paste them.
If you install Outlook on the new computer, quit Outlook, and then copy the
Outlook data files from the old system to the new system, you should be able
to start Outlook and see all your emails.
Earle
H
Hal Hostetler [MVP-P/I]
http://www.slipstick.com/config/backup.htm
Outlook & Exchange/Windows Messaging Backup and Dual-Boot
http://www.howto-outlook.com/Howto/backupandrestore.htm
Backup and Restore
http://www.slipstick.com/config/movepst.htm
To move a Personal Folders .pst file
http://office.microsoft.com/en-us/assistance/HA010771141033.aspx
Reconnect your old Outlook data file
Hal
Hal Hostetler, CPBE -- hhh@xxxxxx
Senior Engineer/MIS -- MS MVP-Print/Imaging -- WA7BGX
http://www.kvoa.com -- "When News breaks, we fix it!"
KVOA Television, Tucson, AZ. NBC Channel 4
Still Cadillacin' - www.badnewsbluesband.com
