Import-CliXml error
D
David Trimboli
I'm trying to import an XML file to a variable, and I get the following
error:
% $client = import-clixml Client_Suddenlink-NewHire_Export-20080421.xml
Import-Clixml : Element 'Objs' with namespace name
'http://schemas.microsoft.com/powershell/2004/04' was not found. Lin
e 1, position 40.
At line:1 char:24
+ $client = import-clixml <<<<
I can't post the entire XML file, but I can post the first line, which
is what is causing the cmdlet to stop:
<?xml version="1.0" encoding="UTF-8"?><VisionDataExchange xmlns:xsi =
"http://www.w3.org/2001/XMLSchema-instance">
Can anyone tell me what's wrong here?
David
Stardate 8486.3
O
/\\/\\o\\/\\/
import-cliXML is not for "general" XML reading but for de-seralizing
PowerSHell objects seralized with export-CliXMLin a "special" PowerShell XML
format (schema) (hence the CLI command line interface) in the name
You need to use PowerShell's XML support for this kind of tasks :
try :
$client = [xml](get-content Client_Suddenlink-NewHire_Export-20080421.xml)
enjoy,
Greetings /\/\o\/\/
http://thePowerShellGuy.com
"David Trimboli" <trimboli@xxxxxx> wrote in message
news:%23AMaK251IHA.3884@xxxxxx
> error:
> e 1, position 40.
> At line:1 char:24
> I can't post the entire XML file, but I can post the first line, which is
> David
> Stardate 8486.3
D
David Trimboli
Oh! Silly me! Thanks, Shay.
David
Stardate 8486.4
Shay Levi wrote:
> To import your own XML files, try:
> PS > $xml = [xml] (get-content
> PS > $xml
> DT> I'm trying to import an XML file to a variable, and I get the
> DT> following error:
> DT> DT> % $client = import-clixml
> DT> Client_Suddenlink-NewHire_Export-20080421.xml
> DT> Import-Clixml : Element 'Objs' with namespace name
> DT> 'http://schemas.microsoft.com/powershell/2004/04' was not found. Lin
> DT> e 1, position 40.
> DT> At line:1 char:24
> DT> + $client = import-clixml <<<<
> DT> I can't post the entire XML file, but I can post the first line,
> DT> which is what is causing the cmdlet to stop:
> DT> DT> <?xml version="1.0" encoding="UTF-8"?><VisionDataExchange xmlns:xsi
> DT> = "http://www.w3.org/2001/XMLSchema-instance">
> DT> DT> Can anyone tell me what's wrong here?
> DT>
K
Karl Prosser[MVP]
import-clixml isn't for importing general XML files.. Its for importing
serialized powershell objects that were generated from export-clixml
to load an XML file you can simply load its strings, then cast it to an
XmlDocument
i.e
$a = [xml](get-content myfile.xml)
> error:
> e 1, position 40.
> At line:1 char:24
S
Shay Levi
Hi David,
Are you trying to import your *own* XML files?
You use the Export-CliXml cmdlet to serialize a .NET object/collection into
an XML file. You can read it back into an object using the Import-CliXml
cmdlet.
For more help and usage examples, type:
PS > help Import-Clixml -full
PS > help Export-Clixml -full
BTW, the first line of exported file (using export-clixml) should look like:
<Objs Version="1.1" xmlns="http://schemas.microsoft.com/powershell/2004/04">...
PS > $xml = [xml] (get-content Client_Suddenlink-NewHire_Export-20080421.xml)
PS > $xml
Shay Levi
$cript Fanatic
http://scriptolog.blogspot.com
DT>
DT>
DT>
DT>
