Inbox emails disappear and we cannot retrieve them - how can we keep them from disappearing and see
  • Thread starter Brian and Jeanne Kottas
  • Start date
Re: Inbox emails disappear and we cannot retrieve them - how can we keep them from di
Depends. If you are using Windows Mail I wouldnt. Its very unstable. If its Outlook 2007 depends on whether your email account is a pop account or an Imap account. If its an imap account you are just clicking on the wrong link. I dont think you can recover lost emails but Outlook 2003 and 2007 under the help tab click "repair". Works great hope that helps!!
G
Gary VanderMolen
It helps if you explain your issue by using all that white space
in the body of the message instead of trying to cram everything
into the subject line.
Open the Inbox folder, then look near the upper right corner.
Does it say "Hide Read Messages" or "Show All Messages"?
You want the latter setting for what is known as the 'Current View'.
Each folder saves its current view setting, so check that setting in
every folder.
Gary VanderMolen, MS-MVP (Mail)
"Brian and Jeanne Kottas" <bjkottas@xxxxxx> wrote in message news:u4dGYWibJHA.4172@xxxxxx
Its not an issue thats just sugarcoating what it really is which is a problem. Lets not get politically corrent on here. Plus the people to post this problem havent responded as to whether its Windows Mail...Outlook 2007, XP or 2003? So before anyone else gives out possible solutions lets wait to see if the person says which version it is they have a PROBLEM with.
E
Email disappearing
I have Microsoft Windows, Vista Premium. I have emails disappearing
from the Inbox. View says ALL MESSAGES.
There are no rules. I searched all files for the missing emails. They
disappear when they first come in and after only being viewable for a
second or two.
S
Steve Cochran
Disable any antivirus software and then remove your mail account, close and
reopen WinMail and then add your mail account back again. See point 3 here:
www.oehelp.com/OETips.aspx#3
steve
"Email disappearing" <Email disappearing@xxxxxx> wrote in
message news:3D51E029-4274-4C21-BAB1-9B5D3C629FE4@xxxxxx
> second or two.
