Initialize Junk Mail Filtering and MSOE.DLL could not initialize
R
RainbowKid
I get the following back to back errors when trying to start Windows Mail:
"Windows Mail could not be started initialize junk filtering. Your computer
may be out of memory or your disk is full (0x80070002)" after I click OK then
I get
"Windows Mail could not be started because MSOE.DLL could not be initialized"
I am running Norton Security Online provided by ATT/Yahoo. At first there
were no problems with Norton running. I had to reinstall Norton and then got
these error messages.
Can anyone help??
Ken
G
Guest
"RainbowKid" <RainbowKid@xxxxxx> wrote in message
news:1A139EE9-861C-44A1-81E3-2010F4AC08CE@xxxxxx
> computer
> then
> I get
> initialized"
> got
> Can anyone help??
> Ken
Norton and McAfee antivirus programs are known to cause problems with
Windows Mail, although usually not immediately. You may have to
uninstall the Norton program, install the download often recommended
here for Windows Mail problems, and then see if you need to do more
to fix the problem.
G
Gary VanderMolen
Windows Mail is not compatible with most McAfee and
Norton security programs. Those will need to be uninstalled,
not just disabled.
After uninstalling your non-compatible antivirus, download
and install a more compatible antivirus like the free Avast:
http://www.avast.com/eng/avast_4_home.html
Even compatible antivirus programs will need to have their
email scanning option turned off. For more on this topic see
http://www.oehelp.com/OETips.aspx#3
Gary VanderMolen [MS-MVP WLM]
"RainbowKid" <RainbowKid@xxxxxx> wrote in message news:1A139EE9-861C-44A1-81E3-2010F4AC08CE@xxxxxx
> I get
> Can anyone help??
> Ken
S
Sean P. Cramer
Re: Initialize Junk Mail Filtering and MSOE.DLL could not initiali
I don't have Norton or McAffee and I have the same error message. Is there a
way just to get the bad file back? I have AVG as my antivirus program.
> not just disabled.
> > I get
> > Can anyone help??
> > Ken
G
Gary VanderMolen
I don't understand your reference to getting "the bad file back."
Have you tried it after uninstalling AVG?
"Sean P. Cramer" <Sean P. Cramer@xxxxxx> wrote in message
news:5E002923-02B5-4120-A8F3-E6685B4DE200@xxxxxx
>> not just disabled.
>> > I get
>> > Can anyone help??
>> > Ken
S
Sean P. Cramer
I just uninstalled AVG, and it didn't remedy the problem. About the "bad
file back". It says msoe.dll can't initialize. Would I be able just to get
that file and paste it over the current one?
Do you have any other ideas?
> >> not just disabled.
> >> > I get
> >> > Can anyone help??
> >> > Ken
G
Gary VanderMolen
That error message is not very helpful. There probably is nothing wrong
with that msoe.dll file. Basically it means that Windows Mail can't start up
because of severe database corruption.
At this point your best course of action is to upgrade to the Windows Live
Mail program: http://get.live.com/wlmail/overview
"Sean P. Cramer" <SeanPCramer@xxxxxx> wrote in message
news:3C2AF3FA-FC97-461F-87E5-60B850CF63D6@xxxxxx
I
ittybitty
#8
I am having this same problem. Up until yesterday all was well. Now I get
this error message. Do I assume that this windows upgrade to get.live.com
will work in windows vista? I wouldn't want to download yet another program
that won't work.
Gladys Rogers
Dayton, Tx.
G
Gary VanderMolen
#9
Yes, I've been using it successfully in Vista for the past 11 months.
Gary VanderMolen, MS-MVP (WLMail)
"ittybitty" <ittybitty@xxxxxx> wrote in message news:176230DF-DFF9-4751-8636-7AC7C3273F58@xxxxxx
> that won't work.
> Gladys Rogers
> Dayton, Tx.
I
ittybitty
#10
So, am I understanding this correctly. Windows mail is corrupted and I will
NEVER get what I had stored there back? I can use WIndows live but cannot
ever use windows mail again. This is not good. Surely there is some way
to get what I had stored in windows mail back.
Gladys
> > that won't work.
> > Gladys Rogers
> > Dayton, Tx.
G
Gary VanderMolen
#11
Not to worry. When you install Windows Live Mail it will automatically
import all your Windows Mail accounts, settings, and emails.
Also, it does not delete anything. You can always go back to Windows Mail
if you want.
"ittybitty" <ittybitty@xxxxxx> wrote in message news:74C8F438-C857-4A4F-A6E4-1CAE154ABCEA@xxxxxx
> Gladys
>> > that won't work.
>> > Gladys Rogers
>> > Dayton, Tx.
I
ittybitty
#12
Great! I am glad of that. I must be setting it up wrong because I cannot
sign on. What can I do to get it working? I have put incoming mail as:
mail.cebridge.net and outgoing as SMTP.cebridge.net. Am I doing something
wrong?
> if you want.
> > Gladys
> >> > that won't work.
> >> > Gladys Rogers
> >> > Dayton, Tx.
G
Guest
#13
cebridge.net doesn't seem to have put instructions for setting up to use
their email servers on their web site. You may have to ask them for such
instructions:
http://support.cebridge.net/contact.php
news:903A7CE0-AC82-4025-9054-F58B3802C9F3@xxxxxx
> wrong?
>> if you want.
>> > will
>> > cannot
>> > way
>> > Gladys
>> >> >I get
>> >> > get.live.com
>> >> > program
>> >> > that won't work.
>> >> > Gladys Rogers
>> >> > Dayton, Tx.
>> >> >> wrong
>> >> >> start up
>> >> >> Windows Live
>> >> >> message
>> >> >> >the "bad
>> >> >> > just to get
>> >> >> >> back."
>> >> >> >> wrote in message
>> >> >> >> >message. Is there a
>> >> >> >> > program.
G
Gary VanderMolen
#14
According to http://support.cebridge.net/outlookexpresssetup.php
the incoming mail server is pop3.cebridge.net.
If you still get an error message, please post it here verbatim.
"ittybitty" <ittybitty@xxxxxx> wrote in message news:903A7CE0-AC82-4025-9054-F58B3802C9F3@xxxxxx
> wrong?
>> if you want.
>> > Gladys
>> >> > that won't work.
>> >> > Gladys Rogers
>> >> > Dayton, Tx.
