initialize USB disk
T
The Clarks
Hi, I have Vista and I have a hard drive that I had for my personal stuff
from XP, my son installed it into my new PC then I got the drive
disconnected so as not to void the warranty when the technician from Acer
came to fix a problem I was having. I decided to get a casing for the drive
and use it as a USB device but can't initialise the disk.
I go to control panel/admin. tools/computer management/disk management. My
disk shows but I don't know how to initalize from there. When I right click
I get a help message only and not the options I get when I right click my
other drives.
The guy who sold me the casing installed the drive for me and I'm sure it is
OK as it shows that the disk is there.
It doesn't show when I look in the computer.
Thanks, I hope I have explained my problem properly
P
Patrick Keenan
"The Clarks" <mandtclark@xxxxxx> wrote in message
news:000625B5-A71F-42E0-A869-7D5ECF6FC6F6@xxxxxx
> drive and use it as a USB device but can't initialise the disk.
> My disk shows but I don't know how to initalize from there. When I right
> click I get a help message only and not the options I get when I right
> click my other drives.
> is OK as it shows that the disk is there.
You were using this drive, and you have data on it? In that case you do
not have to initialise it. That's really only necessary before it's been
partitioned.
Try assigning it a drive letter, and at worst you can try the command line
version of the disk management utility. Open a command prompt and type
"diskpart", and then work through the commands. Basically the process is
to list the disks, select the disk you want, list the partitions, select the
partition you want, assign it a drive letter. In diskpart, the ? key will
get you the help text. You don't have to list the items if you know
exactly what they are, but it helps to be sure.
The syntax is like this:
List disk
Select disk 2
List partition
Select partition 1
assign
exit
and at this point, you should be able to see the drive with a letter in My
Computer and Explorer.
HTH
-pk
O
Opinicus
"Patrick Keenan" <test@xxxxxx> wrote
> you can try the command line version of the disk management utility.
> Open a command prompt and type "diskpart", and then work through the
> commands. Basically the process is to list the disks, select the disk
> you want, list the partitions, select the partition you want, assign it a
> drive letter. In diskpart, the ? key will get you the help text. You
> don't have to list the items if you know exactly what they are, but it
> helps to be sure.
> List disk
> Select disk 2
> List partition
> Select partition 1
> assign
> exit
Boy that sure jogged memories. It's like working through an old "Adventure"
game...
Bob
http://www.kanyak.com
oldun
16
When I bought a brand new drive I could not format it as it was not initialized. Nowhere in Vista could I find out how this is done.
On another forum I found the answer.
Under Control Panel/Disk Management I found the new hard drive to appear but in black, not like the other drives.
Next to the name was a small red cross. Right clicking the red cross allowed me to initialize it?
Why is it so hard to do this in Vista and why is there no help for this process
A
a1000
HI,
I have a somewhat slightly differnt question regarding disk
Initialization...
I installed a usb drive (brand new) and when I went to the Disk Manager
it asked me to initalize the disk so I Clicked yes, and then poof it was
doen..however it initalized the 250 g as a 130 g and I can't get windows
xp to change it . I read the help files and then say to rgiht click the
drive and select initalize but that option never appears...any
suggestions?
Many thanks
a1000
a1000's Profile: http://forums.techarena.in/members/155142.htm
View this thread: http://forums.techarena.in/vista-help/1018262.htm
G
Gene E. Bloch
On Mon, 16 Nov 2009 06:33:18 +0530, a1000 wrote:
> HI,
> Initialization...
> suggestions?
> Many thanks
In Windows the word is Format.
Your BIOS might not allow larger file systems - the number 130 "g" (you
meant GB, right?) rings a bell in my brain.
If your computer is a 5 or 6 years old and running Windows Me, the BIOS
might be the reason.
Gene E. Bloch letters0x40blochg0x2Ecom
R
Roy Smith
#8
a1000 wrote:
> Hi,
> It is an older machine (2006) but its running windows XP. The question
> is how can I re-initialize the drive with the propwer 250 GB as opposed
> to 130 GB.
Right click on My Computer, either on your desktop (if present) or in
the Start menu. In the pop-up menu click on Manage. On the left side
of the Computer Management window click on Disk Management. Now
right-click on the entry for your USB drive and select delete partition.
Finally try to create the partition again.
Roy Smith
Windows XP Pro SP3
A
a1000
#9
Thanks Roy,
Unfortunately I've tried that...several times to no avail. Even on a
newer machine. Seems Once Windows has decided tio initialize the disc as
130GB, that's it. Do you know how Icould perfrom a low level format and
erase the boot sector?
Again thanks in advance
(would a magnet work..lol)
a1000
A
a1000
#10
Considering all the bad luck I've had with hard drives these days ... it
may be that....
I have iniatilized other hard drives using the same enclosure (it's a
5.25 enclosure with removalble drive bays) without any problems.
Are you suggesting I take the drive out and install it in another
computer as a slave drive and then see if windows will re-initialize it
(i.e. re-write the boot sector) once I remove the partition?
or
Am I to take it, that since win xp has written the boot sectoer to
130GB... I'm struck with a 130GB hard drive.
thanks again for all your help guys ...too bad computers are as user
friendly
a1000
