.ink shortcuts are messed up
hazywazy
hi#
there is aproblem with my shortcuts on my desktop
i left my son on the pc when i came back on half my desk top icons had changed to adobe icons
when i clicked on say outlook it tried to open with adobe
the only short fix was to uninstall adobe then all my icons went back to normal
then i tried reinstalling adobe reader and most of the desktop icons changed back to adobe icons
im very confused as i really need adobe for work but cannot have installed on my system untill i get the .lnk set back to its original default, I THINK?
any help please
Brink
Staff member
mvp
Hi Hazywazy, and welcome to Vista Forums.
See if clicking on lnk from the box at this site to download and use the lnkfix_Vista.zip file can fix them for you.
File association fixes for Windows Vista
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
hazywazy
hi
tried this but still does not solve problem
when i reinstall adobe most of my desktop icons are adobe,. even most of my icons on the rest of my pc have now changed to adobe reader
this even includes program files like .exe files not just desktop icons so i think it may be more than just .lnk files
this is confusing as to why these icons have changed to adobe reader on all these differnt file icons
please help
sidney1st
Try to purge your icon cache.
If i remember to do so, open a command prompt as admin, open task manager and stop explorer.exe
In the cmd console go to:
%userprofile%\AppData\Local
Type in: attrib –h IconCache.db then Enter
Type in: del IconCache.db then Enter
Once file deleted, start explorer
hazywazy
hi
trying to type in command prompt but im not sure what u mean by %userprofile%\AppData\Local
on the command promt it says C:\users\'myprofile'\> (do i then type \AppData\Local ) im confused
i ve just opened it up as administrator and now have this prompt windows\system>
but when i try to specify path it wont let me, it just says internal external path not reconised
z3r010
Staff member
Enter this
Code:
cd %userprofile%\AppData\Local
    Windows 10
    me
    Asus RAMPAGE V EXTREME
    Creative
    6 @ 2560x1440
    3x 1TB Samsung Evo 840's
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Logitech Performance MX
    Surface Ergonomic.
    350 Mb/s
    WinTV NovaTD
    HP CP1515n Color Laser
    Microsoft LifeCam Cinema
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    Intel HD Graphics 4400
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
hazywazy
hi
this still does not work
what is the % for either side of the user profile
the cmd panel looks like this C:\windows\system32>(i then input)username\appdata\local
but i get an error
Brink
Staff member
mvp
hi
please help
Is it just the icons that are messed up, or are they also not opened by the correct program to?
If they open with the wrong program to, then try resetting the EXE file extensions back to their default settings as well. This link will show you how to.
Restore the .exe file association in Windows Vista, after incorrectly associating it with another application
If it is just the icons for particular file extensions, then Method One in this tutorial will help show you how to rebuild the icon cache.
http://www.vistax64.com/tutorials/117229-icon-cache-rebuild.html
If it still does not help, then post a list of what file extensions are affected. I will post back the default reg. settings for them.
    Lumia 1520 phone
hazywazy
hi
it is the desktop icons that have changed to adobe reader e.g outlook icon changed etc and when i click to open it tries to open with adobe also program files e,g .exe files have all changed to adobe as well so it seems that when i install adobe it basiclly changed 70% of all my pc icons
hope this helps
Brink
Staff member
mvp
    Lumia 1520 phone
Brink
Staff member
mvp
That's fine since it restores the exe back to the default settings. Afterwards, you should be able to reinstall Adobe without any problems.
    Lumia 1520 phone
hazywazy
hi
touch wood everything seems to fine regarding the download link you provided all icons are back to normal and operating properly
thanks for all your help and any other menbers that posted solutions
thanks again
Brink
Staff member
mvp
Your welcome Hazywazy. I'm happy to hear that it is working now.
This was probably done if an exe file was was right clicked on and the Open With option was selected to use the Adobe program.
    Lumia 1520 phone
