Install Problems Possible Solution>>>>
B
BetaTester9999
Hello
I would suggest as I stated in a previous post that you try to install from
a folder on your drive, from within windows. I must have run this DVD 10
times without success, tried installing SATA drivers and no luck, I only was
able to install without a problem RC1 and RC2 (no problems with the BETA's)
by copying the entire install DVD to a folder and then installing from within
Win XP SP2.
I had no success any other way, I have read that others seem to not have a
problem but I sure did.
Make BACK UP's of DATA you don't want to LOSE!!!!!!!!!!
Good Luck.
Jones
BioStar P4M800-M7 A Motherboard
Intel 840 dual core 3.2 Ghz (not overclocked)
nVidia GeForce 6200 AGP w/512mb memory
2Gb PC3200 RAM
HP DVD Writer 740e PATA
Maxtor 6L300R0 PATA drive 300Gb (Boot)
Maxtor 6V300F0 SATA drive 300Gb
Maxtor 6V200E0 (2) VIA SATA in a RAID 1, 200Gb
HDS72252 5VSA80 SATA drive 250Gb
Iomega USB Drive 200Gb (think it is a seagate)
Hitachi DeskStar on USB Adapter drive 80Gb
500watt PS
Many cooling fans
"There's Things I am and Things I'm Not"
T
i have recently been given a base from work that was a net work they have
delited all windows it has a pentium IIImmx and when starting it up the
message says missing operating system i have a windows 95 disc how do i load
this
"BetaTester9999" wrote:
> Hello
> Win XP SP2.
> Good Luck.
> Jones
> 2Gb PC3200 RAM
> 500watt PS
> Many cooling fans
