Installation problem
My computer came with XP when i bought it(4 years ago). Two years later i upgraded it to Vista without a problem. Now i have decided to reformat my computer with Vista. I changed the boot sequence so the DVD drive is first. I put my disk in and the load bar at the bottom of the screen appears, as if it was going to reformat but then the screen goes black. I waited about 30 minutes just to see if the computer was taking along time to load but it stayed black. I dont think my vista CD is broken since I have used it before. I even tryed another Vista CD that my dad has but the same thing happened. I was curious if I am doing something wrong or if anybody else is having the same problem?
Brink
Staff member
mvp
Hello Jon, and welcome to Vista Forums.
You might check to see if you have the hard drive listed as 2nd in the boot order in the BIOS. Also unplug any external device (Ex: USB drive, printer, etc) other than the monitor, keyboard, and mouse before booting to the Vista installation DVD.
Is your Vista a upgrade or full version?
http://www.vistax64.com/tutorials/68767-clean-install-upgrade-vista.html
or
http://www.vistax64.com/tutorials/117366-clean-install-full-version-vista.html
Hope this helps for now,
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
