Installer Issue
J
Jimbo
I am running Windows Update for Vista Business 64Bit and get this error
message when running windows updates. I just attached a PDA, and, couldn't
get ActiveSync to install. "The Windows Installer Service could not be
accessed. This can occure if the Windows Installer is not correctly
installed. Contact your support personnel for assistance" Any thoughts???
C
Chad Harris
Hi Jimbo--
Try the good ole 'Error 1719 MSKB' while made for XP should work in Vista.
Don't dispair that the title is for error 1719. Just follow Part One:
The Win Installer Service Could Not Be Accessed
http://support.microsoft.com/kb/315346
Good luck,
CH
"Jimbo" <Jimbo@discussions.microsoft.com> wrote in message
news:41BFA66B-0C3D-4F4F-BF74-7A4DDF91928D@microsoft.com...
> thoughts???
C
Chad Harris
Jimbo--
In looking at the hits for this error on Vista when the msiexec has become
dissociated, I have seen reports that the MSKB for XP which does work in XP
doesn't work in Vista nor does SFC. If that's the case for you, then try
recovering from the Vista DVD this way:
You can try a restore point to before this happened or you can try the
steps
below for a Startup Repair from the Recovery Link on the DVD if you have a
Vista DVD:
Pressing F8 repeatedly when you seem the firmware screen may be is a generic
way to launch Windows RE on some OEM Vista computers.
Startup Repair will look like this when you put in the Vista DVD:
http://www.vistaclues.com/wp-content/uploads/2006/12/click-repair-your-computer.png
You run the startup repair tool this way (and system restore from here is
also sometimes effective):
http://support.microsoft.com/kb/925810/en-us
How To Run Startup Repair In Vista Ultimate (Multiple Screenshots)
http://www.windowsvista.windowsreinstall.com/vistaultimate/repairstartup/index.htm
I'm going to give you a bunch of links and most of them you won't have to
use, but they are alternative ways to fix Vista.
Right now I want you to put in the DVD and restart. It will automatically
take you to this on your screen:
That will allow you to go to the Vista setup that has a Repair link on the
lower left corner>click it and then you'll see a gray backgrounded list and
I want you to click Startup Repair from it and follow the directions.
The gray screen after you click the first link in the above pic will look
like this:
http://www.windowsreinstall.com/winvista/images/repair/staruprepair/Image17.gif
Click Startup Repair, the link at the top and after it scans>click OK and
let it try to repair Vista. It will tell you if it does, and if not
This should work, but if not,then you can follow the alternative ways to fix
this including booting into Safe Mode by tapping the F8 key and using System
Restore.
Directions and links for alternative ways to fix this are below, but I hope
you won't need them:
If you have any questions on getting the Startup Repair done, just post
them.
If you have a Vista DVD try Startup Repair. If that doesn't work, try
SafeMode>System Restore from the Recovery Environment, and you always have
the F8 advanced options ( five of them including Last Known Good
Configuration) and a repair install (with the DVD) as well.
In addition you can use the Bootsect tool to manually repair the boot sector
by accessing the command prompt from the DVD or from F8 and typing at the
prompt:
****Ten Methods to Repair BSOD No Boots or Serious Problems in Windows
Vista****
***Startup Repair and System Restore from the Win Recovery Environment on
the DVD***
Although MSFT's Official Party Line as expressed by the Win RE team is that
Startup Repair is only to fix startups, like a lot of features rtm'd that
have broader application, so does Startup Repair. I have used it many times
to fix major systemic problems in Vista when it would still boot
successfully, and am talking with them to try to find out why they seem to
bill it as only fixing startup problems.
You can run Startup Repair by putting your Vista DVD in after theanguage
screen in setup. You can also run System Restore from the same
location.
Note The computer must be configured to start from a CD or from a DVD. For
information about how to configure the computer to start from a CD or from a
DVD, see the information that came with the computer.
2. Restart the computer. To do this, click Start, click the arrow next to
the Lock button, and then click Restart.
This usually means that you enter bios setup by whatever key or keys
(sometimes there is more than one key that will do it for your model--go to
pc manufacturer site) and configure CD to be first in the boot order (this
will allow you to boot from the Vista DVD as well):
See for ref:
Access/Enter Motherboard BIOS (applies to Vista as well)
http://www.michaelstevenstech.com/bios_manufacturer.htm
Boot Order in Bios (Set Boot from HD 1st)
http://www.short-media.com/images/mm/Articles/build_computer/bios/bios03.jpg
Note If you cannot restart the computer by using this method, use the power
button to turn off the computer. Then, turn the computer back on.
3. Set your language preference, and then click Next.
Note In most cases, the startup repair process starts automatically, and you
do not have the option to select it in the System Recovery Options menu.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, click the operating system
that you want to repair, and then click Next.
6. In the System Recovery Options menu, click Startup Repair to start the
repair process.
7. When the repair process is complete, click Finish.
Additional References for Startup Repair With Screenshots:
How to Use Startup Repair:
***Accessing Windows RE (Repair Environment):***
1) Insert Media into PC (the DVD you burned)
2) ***You will see on the Vista logo setup screen after lang. options in the
lower left corner, a link called "System Recovery Options."***
Screenshot: System Recovery Options (Lower Left Link)
http://blogs.itecn.net/photos/liuhui/images/2014/500x375.aspx
Screenshot: (Click first option "Startup Repair"
http://www.leedesmond.com/images/img_vista02ctp-installSysRecOpt2.bmp
3) Select your OS for repair.
4) Its been my experience that you can see some causes of the crash from
theWin RE feature:
You'll have a choice there of using:
1) Startup Repair
2) System Restore
3) Complete PC Restore
___________________
prompt:
Bootsect.exe is available from the \Boot\folder of the Windows Vista DVD and
can be run from within System Recovery or Windows XP on a dual boot.
1. Use Bootsect.exe to restore the Windows Vista MBR and the boot code that
transfers control to the Windows Boot Manager program. To do this, type the
following command at a command prompt: Drive:\boot\Bootsect.exe /NT60 All
In this command, Drive is the drive where the Windows Vista installation
media is located.
Note The boot folder for this step is on the DVD drive.
2. Use Bcdedit.exe to manually create an entry in the BCD Boot.ini file for
the earlier version of the Windows operating system. To do this, type the
following commands at a command prompt.
Note In these commands, Drive is the drive where Windows Vista is
installed. . Drive:\Windows\system32\Bcdedit /create {ntldr} -d "Description
for earlier Windows version"
Note In this command, Description for earlier Windows version can be any
text that you want. For example, Description for earlier Windows version can
be "Windows XP" or "Windows Server 2003".
.. Drive:\Windows\system32\Bcdedit /set {ntldr} device partition=x:
Note In this command, x: is the drive letter for the active partition.
.. Drive:\Windows\system32\Bcdedit /set {ntldr} path \ntldr
.. Drive:\Windows\system32\Bcdedit /displayorder {ntldr} -addlast
3. Restart the computer.
____________________________
******Using the BootRec.exe Tool
Using the System Recovery Tool from the Repair link on the DVD after the
language choice in the lower left hand corner you can select command prompt
and you have the following options:
Bootrec.exe (You can use this tool to recover Vista even when you do not
receive the error message that is the title of the 2nd linked MSKB below):
How to use the Bootrec.exe tool in the Windows Recovery Environment to
troubleshoot and repair startup issues in Windows Vista
http://support.microsoft.com/kb/927392/en-us
Error message when you start Windows Vista: "The Windows Boot Configuration
Data file is missing required information"
http://support.microsoft.com/kb/927391/en-us
_____________________________________________________________
***Using the F8 Environment or a Repair Install from the DVD:***
See for ref:
Access/Enter Motherboard BIOS (Applies to Vista as well)
Repair Install (for XP or Vista)
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/tips/doug92.mspx
Repair Install (Method 2): (for XP or Vista)
http://support.microsoft.com/default.aspx/kb/315341
***Taking Full Advantage of the F8 Options (Windows Advanced Options Menu)
by starting the PC and tapping F8 once per second when the firmware screen
with the pc manufacturer's name shows a few seconds after restarting***:
The F8 options in Vista are the same as XP, and the link for Safe Mode Boot
options is labled XP by MSFT but they are the same for Vista (they haven't
updated to add Vista to the title as they have with several MSKBs that apply
to both).
Again, pressing F8 repeatedly when you seem the firmware screen may be is a
generic way to launch Windows RE on some OEM Vista computers.
You could also:
Think: I have 4 different ways to get back my XP at F8 and try 'em in order.
1) Safe Mode 2) Safe Mode with Cmd to Sys Restore which is simply a cmd
prompt in safe mode 3) Safe Mode with Neworking 4) LKG or Last Known Good
Configuration
Try to F8 to the Windows Adv Options Menu>try 3 safe modes there (I don't
use WGA) and Last Known Good>then I go to Win RE in Vista. That gives you a
choice of Safe Mode, Safe Mode with Networking,and Safe Mode with Command
Prompt.
These methods are outlined in
A description of the Safe Mode Boot options in Windows XP/and Vista
http://support.microsoft.com/kb/315222/
Frequently Asked Questions Regarding System Restore from MSFT:
http://www.microsoft.com/technet/prodtechnol/winxppro/plan/faqsrwxp.mspx
System Restore can be run from the Win RE recovery environment from the same
link as Startup Repair, and sometimes it will work from one F8 safe mode
location or from the Win Recovery Environment when it won't work from other
locations.
How to start the System Restore tool at a command prompt in Windows XP
http://support.microsoft.com/default.aspx?scid=kb;en-us;304449
Repair Install: (This option has the best chance of succeeding and it
preserves everything in your OS--you do not lose anything with this option):
Make sure the DVD you have is a Vista DVD. Many OEMs will send you a
Recovery DVD and it may restore you to factory settings, but a high
percentage of the time it does not in my experience.
Pitfalls: If the DVD came from friend or relative or P2P, you may have
problems. P2P besides being illlegal in many countries including the U.S.
can be corrupt. If CD came from friend or relative, they may have given
you the CD to use but if product key is in use, MSFT is not going to accept
it for activation. Make sure you clean the CD carefully using proper
cleaning fluid and strokes that radiate from center like spokes on a wheel.
Again a repair install has the most likely chance to succeed in XP, (and can
work in Vista) but you need
to have a Vista DVD.
First, in order to do a Repair Install You must boot to the bios setup and
position booting from the "CD" first in the boot order--it probably will not
say DVD but might.
Booting to Bios Setup:
For 85% of PC's and all Dells you can tap the F2 key to reach bios setup.
How To Enable DVD/CD Rom Support (put CD boot first) in bios setup boot
order:
http://xphelpandsupport.mvps.org/how_do_i_enable_cdrom_support_i.htm
Screen Shot of bios setup boot order:
http://www.poy.net/proxy/bios2.jpg
Repair Install Does Not Lose Anything; you may need to try 2-3 times but
that's rare.
How To Repair Install (Applies to Vista as well as XP)
http://support.microsoft.com/kb/315341#XSLTH3127121122120121120120
Screen Shot Repair Install
http://www.windowsreinstall.com/winxppro/installxpcdrepair/indexfullpage.htm
Good luck,
CH
> thoughts???
J
Jimbo
Chad,
Thanks for all the info. I am a consultant and learning Vista. I ended up
completely redoing the drive, as I had all my data backed up. I am, however,
going to print and study this information.
Thanks!
"Chad Harris" wrote:
>c
W
WallyK
Chad:
I am having this very same problem. I already found the kb entry 31546.
They posted 2 methods to fix this. I tried method 1, and it did not work.
I attempted method 2, which would "reinstall" the installer. To do this you
have to rename certain files, i.e. msi.dll. When I tried to rename, I got a
message saying I was not authorized to perform the function. Do you have to
be signed on as "The Administrator" to modify system files, or can I just
change the attributes of the files to not be system files?
I was signed on as an administrator.
Thanks for your help
> Hi Jimbo--
> Good luck,
> CH
> > thoughts???
