Installing two operating s on 2 seperate hard drives...
Is this possible on a laptop? If yes how would one decide to boot from one or the other?
    HP HD X9050 20,1" widescreen (laptop)
    Intel Core 2 Duo T7700 / 2.4 GHz
    DDR II SDRAM 2GB( max 4gb)
    ATI Radeon HD 2600XT 256RAM
    20.1 in TFT active matrix (Ultra BrightView Widescreen)
    max 1680 x 1050
    Serial ATA : 2x120GB 5400rpm (Work Drive)
    SATA/300 16MB 1x160GB 7200RPM (Game Drive)
    cordless
    Gigabit Ethernet , Ethernet , Fast Ethernet Mobile Broadband
    1.0 Memory , 2.0 Memory card reader , 1.0 ExpressCard 54/34 Interfaces 1.0 x Ethernet - USB 2.0 , 1.0 x USB 2.0 - RJ-11 , 1.0 x Expansion - RJ-45 , 1.0 x Display / video - VGA , 1.0 x Speaker , 1.0 x IEEE 1394 (FireWire) , 1.0 x SPDIF , 1.0 x TV-Out , 1.0 x Consumer IR , 1.0 x eSATA , 4.0 x Modem , 1.0 x HDMI , 1.0 x Headphones , 1.0 x Microphone , 2.0 x TV tuner
fadedrs
Lost in my own World
Power User
yes it is possible to do.
you will need a boot manager to switch between the different os's
    CUSTOM BUILT BY ME
    8BG PC5300 4 x 2GB OCZ
    Onboard 7.1 HD AUDIO
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    MICROSOFT WIRELESS MOUSE
    MICROSOFT WIRELESS KEYBOARD
    CABLE 15MBPS
Thank you. Could you explain to me how is done or post a link to a easy tutorial on how it is done please?
    max 1680 x 1050
    cordless
fadedrs
Power User
when you are installing the second os make sure you select the second hard drive.
See: http://www.vistax64.com/tutorials/224397-dual-boot-installation-windows-vista-xp.html
read below same thing except you don't have to shrink the hard drive.
Install Windows XP on Your Pre-Installed Windows Vista Computer
The question I am asked most often is “How do I install a dual-boot with Windows XP on my new Windows Vista computer?” The answer is that it’s not that difficult, it’s just very time consuming, and you need to own a copy of Windows XP.
Note that you should not attempt this if you aren’t ready to troubleshoot any problems that might occur.
The first issue we encounter is that computers with pre-installed operating systems take up the entire drive. Luckily Microsoft included the Shrink volume feature in Vista, so we can easily shrink the Vista partition down to make room for XP.
Open the Computer Management panel, which you can find under Administrative tools or by right-clicking the Computer item in the start menu and choosing Manage. Find the Disk Management item in the list and select that.
Now we’ll shrink our volume down by right-clicking on the main hard drive and choosing Shrink Volume.
Now you can choose the size that you want to shrink, which really means you are choosing the size that you want your XP partition to be. Whatever you do, don’t just use the default. I chose roughly 10gb by entering 10000 into the amount.
The next step might be confusing, because we need to change the cd-rom drive that’s invariably taking up D: at the moment, because we want to use D: for the Windows XP partition, but it’s already taken by the cd-rom drive. If you skip this step than XP will install onto the E: drive, which isn’t the end of the world, but it’s not quite as tidy.
Right-click on the cd-rom drive in the list and choose Change Drive Letter and Paths from the menu.
Now we’ll change the CD drive to use E: by selecting that in the drop-down.
Now we can create a new partition for XP to live on and make sure that the drive letter is set the way we want. If you do not create a partition now the XP install will do so automatically, but it’s easier and cleaner to do it this way.
Right-click on the Unallocated free space area and then select New Simple Volume from the menu.
Follow through the wizard and select whatever options you’d like, making sure to use D: as the drive letter.
Now you will need to close out of disk management and reboot your computer. This is because we can’t do the next step until we reboot. (you can try, but it won’t work)
So we’ve come back from rebooting… open up Computer from the start menu and then right-click on the D: drive and select properties. Give your partition a meaningful name like “XP”. It would be wise to name the C: drive to “Vista” at this point as well.
Now you’ll want to pop your XP cd into the drive and boot off it. You may have to configure your BIOS to enable booting off the CD drive, or if your computer says something like “Hit Esc for boot menu” you might want to use that.
Once you come to the screen where you can choose the partition to install on, then choose either the unpartitioned space or the new partition you created. Whatever you do, don’t try and install onto your Vista partition! See how much cleaner it is now that we’ve labeled each partition distinctly?
We’ll assume XP is completely installed at this point, and you will have lost your ability to boot into Windows Vista, so we’ll need to use the VistaBootPro utility to restore the Vista boot loader.
Update: VistaBootPro is no longer free, but you can still download the free version.
During the install you’ll be forced to install the .NET 2.0 framework. Open up VistaBootPRO and then click on the System Bootloader tab. Check the “Windows Vista Bootloader” and then “All Drives” radio buttons, and then click on the Install Bootloader button.
At this point, the Windows Vista bootloader is installed and you’ll only be able to boot into Vista, but we’ll fix that. Instead of manually doing the work, we’ll just click the Diagnostics menu item and then choose Run Diagnostics from the menu.
This will scan your computer and then automatically fill in the XP version.. click on the “Manage OS Entries” tab and then click in the textbox for Rename OS Entry, and name it something useful like “Windows XP” or “The Windows That Works”
Click the Apply Updates button and then reboot your computer… you should see your shiny new boot manager with both operating systems in the list!
If you get an error saying “unable to find ntldr” when trying to boot XP, you’ll need to do the following:
  • Find the hidden files ntldr and ntdetect.com in the root of your Vista drive and copy them to the root of your XP drive.
  • If you can’t find the files there, you can find them in the \i386\ folder on your XP install cd
There’s more information on this forum thread, thanks to nrv1013
This is a critical piece of information: Windows XP will be installed on the D: drive, even in Windows XP… so you’ll need to keep that in mind when tweaking your system.
You can share information between the drives, but I wouldn’t recommend messing with the other operating system’s partition too much… it might get angry and bite you. Or screw up your files. What I do recommend is that you store most of your files on a third drive shared between the operating systems… you could call that partition “Data”.
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
Thank you. I will give this a try. Looks like a long process but I think I can do it. So I will start from where you have to decide where to install the second operating system, right?
    max 1680 x 1050
    cordless
fadedrs
Power User
correct cause you are going to use two drives you DO NOT have to shrink your primary drive.
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
