Installing Visual Studio 2005 on Vista
  • Thread starter Carl Daniel [VC++ MVP]
  • Start date
C
Has anyone had any luck installing VS2005 on Vista 5365?
I'm having no joy at all - the setup program completely craters before even
starting the install. Ironically, VS did install successfully on 5308,
which was otherwise too buggy to work on.
-cd
A
Andre Da Costa [Extended64]
I have not attempted, it did install successfully for me on 5308 also. Have
you disabled or UAP to see if it installs then?
Andre
Windows Connected | http://www.windowsconnected.com
Extended64 | http://www.extended64.com
Blog | http://www.extended64.com/blogs/andre
http://spaces.msn.com/members/adacosta
"Carl Daniel [VC++ MVP]" <[email protected]>
wrote in message news:[email protected]
> even starting the install. Ironically, VS did install successfully on
> 5308, which was otherwise too buggy to work on.
> -cd
C
> also. Have you disabled or UAP to see if it installs then?
Yes, I disabled it. I hadn't disabled in under 5308 - maybe I'll try
turning it back on to see if that helps.... (wouldn't that be ironic!)
-cd
S
Slugsie
Yup, I got it to install - eventually. The setup crashed out quite a few
times, and then it just worked and the install went flawlessly.
</Slugsie>
> -cd
C
> few times, and then it just worked and the install went flawlessly.
Gee... that's.... encouraging? I've only tried twice so far - maybe if I
give it another few tries I'll get lucky...
-cd
C
> before even starting the install. Ironically, VS did install
> successfully on 5308, which was otherwise too buggy to work on.
I turned off a few things:
- UAC (aka UAP) (actually, I tried it both ways, but in the end, it's off)
- DEP/NX
- Security Center service
- Superfetch service
- Windows Search service
.... and now the VS installer is running. Of those, I strongly suspect that
it's DEP/NX that made the difference, but who knows...
-cd
