Internet speed fractured in Vista!
djmorgan
User
Power User
31
Location
Gold Coast Queensland Oz
Right now I have XP Pro SP3 on 1 laptop and Vista Ultimate on another I have an ADSL 2+ Internet connection
With the XP machine I get 28000+kbs down and 750+ up, using the same connection just swapping the net cable Vista does 9000+ down and 750+ up.
I have tried every "Netsh" combo detailed here and elsewhere with nil result what can be wrong with Vista? :cry:
1,823
Get a newer NIC driver. Disable IPv6 in the NIC settings.
    16GB DDR667
    SAS RAID
1,823
Try setting the speed to 100 Mbps / full duplex instead of auto. Try disabling your firewall and anti-virus and see if they are causing problems with downloading.
    16GB DDR667
    SAS RAID
djmorgan
User
Power User
31
Location
Yes full power option, ESS disables native firewall as for defender it's not the easiest to turn off! I've removed it from the registry run, it does not appear in msconfig and or any running services or processes so I think I nailed that sucker too!
MY XP system is nearly the same as the Vista system in terms of AV and firewall, I can rule out the modem as I only swapped the net cable from one to the other.
Google produces a lot of complaints about internet speed with Vista, now I have to say that my system with the internet does not seem slow! but this could be due to the processor power
1,823
#8
Do you have a non-Vista computer to test the internet speed with?
My Vista x64 Ultimate network performance is the same as XP x64.
Cabling
NIC drivers
NIC settings
router problems
Firewire and anti-virus interference
Your CPU is GHz and your network is Mhz. I doubt the CPU performance is the problem unless your CPU is running at 100%. Turn on the gadget with CPU/RAM usage.
Are you using a CAT 5, 5e or 6 cable. I use on CAT 6 for 1 Gbps. The backbone from second floor to basement is CAT 6 plenum grade solid core shielded. 5e is minimum for 1 Gbps.
Firewall and anti-virus can cause issues. Make sure they are disabled.
Did you try directly to the modem? Bypass your router. Maybe the router has issues.
    16GB DDR667
    SAS RAID
1,823
#10
XP on same computer rules out cabling and router issues. I would check speed, duplexing, and drivers.
    16GB DDR667
    SAS RAID
dmex
ɠɛɐǨ
2,632
Location
Fremantle, Western Australia
#11
70
#12
Yes! my XP machine conected to the same cat cable and same route does over 28000+ kbs down and 700+ up.
This is why I know it must be a bottle neck in Vista
I'll check the other items you mention
Hey DJMorgan,
Try out this tutorial, It should help you increase the network speed.
http://www.vistax64.com/tutorials/72308-auto-tuning-tcp-ip-receive-level.html?ltr=ASteven
Just for fun I tried the tutorial. It crippled me. I was not broke so I didn't need it I guess. It took my Gigabit Ethernet connection down to 100. Reversed and all is well.
My details:
No TCP tweaking, bone stock.
Screaming comcast here on an Arris cable modem.
Vista 32 and 64 bit machines.
Trendnet's latest Draft-N router.
    Home Build
    Intel Q6600 G0
    Gigabyte GA-EP45-UD3P
    Corsair 8GB
    POWERCOLOR AX3650 512M DDR2
    On board
    Samsung 215TW
    2X WD 750GB RE3 RAID-1
    610W CORSAIR Modular
    Cheapo Rosewell
    Rosewell Fans and CPU Cooler
    Logitech MX Revolution
    Logitech Access Keyboard 600
johngalt
Antidisestablishmentarian
3,921
Location
3rd Rock
#13
Try swapping the cables ans see if the speeds change....
    Windows 10 Insider Preview current build
    The Beast Model V
    eVGA X58 Classified3
    3 * 4GB Mushkin Enhanced Redline CL7 DDR3 1600 MHz (PC3-12800)
    eVGA GTX 970 + eVGA GTX 560 Ti 448 Core Classified (PhysX)
    Realtek HD Audio (onboard)
    2 * Lenovo LT2323pwA
    2 * 1920 x 1080
    SanDisk Ultra SDSSDHII-960G-G25 SATA III SSD (System)
    Crucial MX100 CT256MX100SSD1 SATA III SSD (User Tree)
    2 * Seagate Barracuda 7200.12 ST31000528AS SATA II
    Seagate ST1500DL001 7200 RPM SATA II
    Intel SSDSA2M080G2GC SATA II SSD
    ThermalTake BlackWidow 850W
    ThermalTake Level 10 GT
    Corsair H100 (CPU) + Air (2 * 210 mm + 3 * 120mm fans)
    Logitech MX Master
    Logitech G15 (gen 2)
    300+ Mbps downstream / 30+ Mbps upstream
    Windows 10 Insider Preview (current)
    Dell Inspiron 3521
    Intel(R) Celeron(R) CPU 1007U @ 1.50GHz
    Dell
    Intel(R) HD Graphics
    Intel(R) Display Audio | Realtek Audio
    Inspiron 15"
    1680 * 1050
    INTEL SSDSC2CW180A
    Dell
    Dell
    Dell
    Logitech MX Master | Synaptics TouchPad
    Dell
    300+ Mbps downstream | 30+ Mbps upstream
djmorgan
User
Power User
31
Location
#15
I really appreciate all your help and thoughts on this matter.
I have tried every Netsh comand known to man and then some! first placed i looked was the tweak tutorial.
I have swapped out every cable even though XP worked great using them.
I have the latest nic drivers, they are actually the only drivers available so I can't roll back
But keep the thoughts and suggestions coming please :p
dmex
ɠɛɐǨ
2,632
Location
#16
The latest driver for this NIC can be found at one of the links below, Give one of them a try and let us know if there is any improvement.
Driver Last updated: 21/May/2008
Mirror 1: ftp://66.104.77.130/cn/nic/Install_Vista_6206_0520.zip
Mirror 2: ftp://61.56.86.122/cn/nic/Install_Vista_6206_0520.zip
Mirror 3: ftp://210.51.181.211/cn/nic/Install_Vista_6206_0520.zip
Steven
1,823
#20
What is your speed and duplex set to? Try 100 Mbps /full duplex. See if that helps.
    16GB DDR667
    SAS RAID
