Solved Internet won't connect to WiFi
JNathanK
3
I can connect to my home router through ethernet with my laptop, and I can connect wirelessly to it with other computers.
My laptop can also connect wirelessly to routers other than the home router. For some reason I'm having issues connecting wirelessly specifically with this laptop through this specific router. I need help troubleshooting. Diagnose and repair said there may be a problem with the DNS configuration.
I can't ping IP addresses either even the internet connection icon on the bottom right of the screen indicates that its connected to both my LAN and internet.
I can't connect to the NAS, so the LAN isn't working either.
Sorry, the title wasn't well thought out. I would have edited it if it was an option.
    HP DV2000
    AMD64
    4 gb DDR2
    NVIDIA
Yard Dog
2,169
Location
Central Florida in a small town
Hello, lets do some cleaning up and see if that helps you out .
How to Flush DNS in Windows Using the Command Prompt
Step 1 – Close all open web browsers and applications on your computer.
Step 2 – Open the Windows command prompt by selecting the “Start” menu and entering “cmd” in the search text field box followed by clicking the “enter” key.
Step 3 – At the command prompt, enter “ipconfig /flushdns” followed by pressing the “enter” key. After a moment, Windows will display a message similar to: “Successfully flushed the DNS Resolver Cache.” Once the message is displayed, the DNS will be flushed removing all incorrect entries.
Then , we want to get the IP reset, so, lets renew its settings and see if this also helps out :
you will type in the command box : ipconfig /release then enter, then next ipconfig /renew then enter, this will reset the IP , now restart and attempt to have it reconfigure its connections to your router. Post back results please.
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
Yard Dog
2,169
Location
Start, all programs. accessories. command prompt, right click it, to run as Admin.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Yard Dog
2,169
Location
Excellent, thanks for using VistaForums. Come back for any issues or for just the excellent Tutorial section..
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
1
So, I am having the same issues as above, have done everything stated and still cannot connect to internet. At network and sharing center it shows my computer connected to unidentified network (which on another laptop states home) and then a big red x connecting to internet.
Under unidentified network it states public, which I have changed to private before with no luck, and access as local only, whereas on my other laptop it states local and internet.
Everything worked fine until about 2 weeks ago when we changed internet provider.
any help would be great!
ilikefree
2,877
Location
New Zealand
#8
On that page (Network and sharing center) try View Status then Diagnose. It will reset the network adapter
If that didn't help try turning on your wireless on the computer and turn off the router at the wall then turn it on again after a few seconds.
Most times it will find and reset the settings for you.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
1
#9
Hello. I tried this and also the command prompt. My connection is still an unidentified public network with local only access.
I've even updated drivers, updated to windows service pack 2.
I have a 5 yr old laptop.
    HP Pavillion dv7-1132nr
ilikefree
2,877
Location
New Zealand
#10
When you click on the red X do you get an error message?
EDIT:Didn't know this was still a problem because you added to someones post that had been flagged as solved
You really needed to start a new post
    LENOVO 64734VM
    15 inch
    External Speakers
