Invoke .Net application
S
srikanth
It is simple web application developed using ASP.Net and C#.
"RichS" wrote:
> If you are talking about a .exe then yes. What sort of application do you
> have?
> Richard Siddaway
> Please note that all scripts are supplied "as is" and with no warranty
> Blog: http://richardsiddaway.spaces.live.com/
> PowerShell User Group: http://www.get-psuguk.org.uk
> "srikanth" wrote:
> > Can I invoke .net application using powershell
S
srikanth
Thanks Shaw
"Marco Shaw" wrote:
> I am not a "programmer", but I seem to remember reading that "invoke" is
> a term that seems more complicated than it seems...
> Take a look here:
> http://www.leeholmes.com/blog/LoadACustomDLLFromPowerShell.aspx
> Sounds like what you're looking for. You just want to load some .NET
> code you created.
> Marco
