Solved Is It Worth Going To 64bit
Posts
40
I just want to hear peoples thoughts, i have a 64 CPU, but only 32 bit vista OS, is it REALLY WORTH upgrading to 64 bit. Are all the compatability issues sorted? Really i just want to know, will i see a noticeable difference in speed?
Thanks, Ben. :D
    AMD Athlon 64 X2 Dual
    Asus nForce 410
    4GB DDR2 667Mhz PC-5300
    GeForfce 6100
    AC'97
    19" Sony
    1024x768
    250GB
    Black
    Air
    Logitech Wireless
    Microsoft Curve
    Up To 16MB
Bare Foot Kid
R.I.P. August 13th 2014
The Lowcountry
Posts
2,616
Hello vistablackben.
I just installed 64-bit Ultimate for the first time ever and I'm having no problems at all.
The only concerns are ...
1. Will all the programs/applications you will want to run do so in 64-bit?
2. Are there drivers available for all the hardware of the machine in question?
If the answer to both of these is yes; then go for it. IMO, get Ultimate, not Home Premium.
Later :shock: Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
sygnus21
Here to learn
Hampton VA
Posts
1,033
Thanks, Ben. :D
Google "Thoughts on Vista 64"
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
Brink
Staff member
mvp
Oklahoma, USA
Posts
32,305
Thanks, Ben. :D
Hi Ben,
I suppose it depends on if you have a 64-bit CPU, 64-bit drivers available for all of your devices, how much RAM (ex: over 3.2 GB) you have or want, and how you use your computer. If yes to these, then 64-bit could be worth it.
The articles in this post may help answer some of your questions to though.
http://www.vistax64.com/vista-news/99613-64-bit-more-than-just-ram.html
    ASUS Maximus X Code Z370
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    Lumia 1520 phone
Posts
1,823
Download all the drivers for your hardware. Include printers, network card, scanners, video cards. Everything. Alot of hardware does not support 64-bit. Make sure none of your programs are 16-bit. You need 32-bit and 64-bit apps. Verify your favorite games will work.
    16GB DDR667
    SAS RAID
Posts
40
i DONT think i can get my chipset, network driver, for 64 bit, looked everywhere, this is the site for my Motherboard.
Foxconn - Support - Downloads
I know i can get audio and onboard graphics for 64, but need my chipset in 64. I dont really play games, just general applications, Nero, MSN, PowerISO, Office, AVG, iTunes, etc etc
    Asus nForce 410
    GeForfce 6100
    AC'97
    19" Sony
    1024x768
    250GB
    Black
    Air
    Logitech Wireless
    Microsoft Curve
    Up To 16MB
Dwarf
The Contemplator
Doncaster, UK
Posts
2,760
Hi Ben,
What is the exact model number of your motherboard?
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
Posts
40
#8
    Asus nForce 410
    GeForfce 6100
    AC'97
    19" Sony
    1024x768
    250GB
    Black
    Air
    Logitech Wireless
    Microsoft Curve
    Up To 16MB
Dwarf
The Contemplator
Doncaster, UK
Posts
2,760
#9
Thanks, Ben.
There are actually 4 models with the part number 6100M2MA. For convenience, I enclose both 32-bit and 64-bit links to the chipset drivers. The Realtek drivers are both 32-bit and 64-bit in the same package. Please note that the Realtek website and downloads are notorious for being extremely slow.
6100M2MA-RS2
32-bit nForce Driver
64-bit nForce Driver
Realtek
6100M2MA-2.0-RS2H
Realtek
6100M2MA-8EKRS2H
Realtek
6100M2MA-R2SH
Realtek
    Gigabyte IF233
Posts
40
#10
TBH i have no idea which one, but thanks anyway, been a great help, the 32 bit ones i got from here, after running aida32 it just returns 6100M2MA
and they all seem to be working fine, so i guess model number may not make a big difference or mine is one of the above, either way, now i have the 3 essential drivers for my hardware in 64 bit, so now i will get 64 bit OS and will consider moving to it. Right now though 32bit vista is running fine and very fast, although i have 4gb RAM i am obviously not seeing that until 64. But as im not running any hardcore games or applications il stay where i am.
Thanks for all the help, Happy Christmas, Ben :party: :D
    Asus nForce 410
    GeForfce 6100
    AC'97
    19" Sony
    1024x768
    250GB
    Black
    Air
    Logitech Wireless
    Microsoft Curve
    Up To 16MB
Dwarf
The Contemplator
Doncaster, UK
Posts
2,760
#11
Hi Ben,
Although I had listed the motherboards individually, they all use the same motherboard drivers. As regards the audio drivers, they all use Realtek and the AC'97 version with the exception of 6100M2MA-8EKRS2H, which uses the HD version.
Good luck with the install, and if you have any problems please post back and we'll endeavour to help you solve them.
    Gigabyte IF233
Brink
Staff member
mvp
Oklahoma, USA
Posts
32,305
#12
Merry Christmas Ben to you as well,
There should be a small white sticker on the motherboard with the exact model and serial number on it. The box it came in should also have a sticker on it with information as well. You wouldn't want to install the wrong chipset and especially BIOS version.
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Logitech MX Master
    Lumia 1520 phone
Posts
40
#13
I know this a noob question but i have heard it happen, my CPU is 64 bit compatible, right? It's a AMD Athlon 64 X2 4000+, thats pretty much all I know?
Thanks Again, Ben :D
    Asus nForce 410
    GeForfce 6100
    AC'97
    19" Sony
    1024x768
    250GB
    Black
    Air
    Logitech Wireless
    Microsoft Curve
    Up To 16MB
Dwarf
The Contemplator
Doncaster, UK
Posts
2,760
#14
Hi Ben,
Yes, your CPU is 64-bit compatible.
    Gigabyte IF233
Posts
40
#15
lol thanks!
    Asus nForce 410
    GeForfce 6100
    AC'97
    19" Sony
    1024x768
    250GB
    Black
    Air
    Logitech Wireless
    Microsoft Curve
    Up To 16MB
