Is there a way to switch between IE tabs?
M
MG
Hi:
I opened a few tabs in IE8 with PowerShell
$ie = New-Object -ComObject InternetExplorer.Application
$ie.Visible = $true
$ie.Navigate("http://intra.tcs.com")
$ie.Navigate("http://www.g.com",0x0800)
$ie.Navigate("http://support.dell.com.cn",0x0800)
Can I switch between these tabs using PoS?
Thanks!
MG
M
Marco Shaw [MVP]
Checking the documentation:
http://msdn.microsoft.com/en-us/library/aa752094(VS.85).aspx
There's a "TargetFrameName" parameter to Navigate2 and Navigate, but I can't
figure out how to use it...
Marco
"MG" <[email protected]> wrote in message
news:uDPe#[email protected]
> Hi:
> $ie.Visible = $true
> Thanks!
> MG
R
Robert Aldwinckle
"MG" <[email protected]> wrote in message news:uDPe#[email protected]
> Hi:
> $ie.Visible = $true
Use SendKeys("Ctrl+Tab")? ; )
Or if you want to open a specific tab n from the first 9:
SendKeys("Ctrl+" n)
Note: the above is pseudocode. I don't know the
proper syntax or supporting infrastructure to actually
do this in PowerShell... ; )
So see perhaps...
http://www.microsoft.com/technet/scriptcenter/topics/winpsh/convert/wshsendkeys.mspx
(Microsoft search for
sendkeys powershell
Good luck
Robert Aldwinckle
> Thanks!
> MG
A
Alex K. Angelopoulos
Could you clarify your question a bit? Do you mean:
(1) How do I bring a particular tab to the front so it¡¯s visible?
or
(2) How do I connect to a particular Internet Explorer window when I have
several open?
For (1), there's no easy way to guarantee this; there _are_ possible hacks.
Everyone hates SendKeys because of its poor reliability, but using that (or
possibly some exposed elements of the free AutoItX component) is probably
the most straightforward way. The new IE method Marco mentioned suggests
another possible solution if frame can be determined, since you could
actually renavigate the top frame to a particular site.
For (2), you _can_ do this, but you need to go in another way. What you've
done using the 0x800 flag ( - a clever trick, by the way! ) is open a NEW
Internet Explorer instance using your original IE as a "starter". The
original IE and all new instances are actually equal children of a global
container IE, and you do NOT currently have a direct connection to the other
IE windows. You basically spun them off.
However, you can use the Shell.Application COM object to get all desktop
shell windows, which include all IE windows. With a bit of filtering, you
can get only the IE instances connected to non-file resources into a set
like this:
$ieSet = (New-Object -ComObject Shell.Application).Windows() |
? {$_.LocationUrl -notlike "file:*"} | ? {$_.LocationUrl}
Note that if you DO want to include local files opened in IE, you can drop
the first filter.
The next thing you need to do is select the IE of interest based on the URL.
Here's where you may encounter a problem: there is NO guarantee that the URL
you end up at is identical to the one you chose to navigate to. For example,
when I use
I end up at the URL
http://support.ap.dell.com/support/index.aspx?c=cn&l=zh
However, if you know something certain to be in the particular URL of
interest, you can use it to select the correct URL:
$ieSet | ?{$_.LocationUrl -like "*.dell.*"}
You can also view the titles and URLs pretty quickly for interactive use
like this:
$ieSet | select LocationUrl,LocationName
Another option to consider is to just go ahead and create a new IE for each
window instead. This ensures you know which IE is important, even if it was
redirected. For example, do this:
function New-IE($url)
$ie.Visible = $true;
$ie.Navigate($url);
$ie;
$ieTcs = New-IE http://intra.tcs.com
$ieG = New-IE http://www.g.com
$ieDell = New-Ie http://support.dell.com.cn
> Hi:
> $ie.Visible = $true
> Thanks!
> MG
M
MG
Thank you very much for the details explanation. I think (2) is match my
requirement.
MG
"Alex K. Angelopoulos" <alex(dot) k(dot again)angelopoulos(at)gmail.com>
wrote in message news:[email protected]
> or
> several open?
> hacks. Everyone hates SendKeys because of its poor reliability, but using
> that (or possibly some exposed elements of the free AutoItX component) is
> probably the most straightforward way. The new IE method Marco mentioned
> suggests another possible solution if frame can be determined, since you
> could actually renavigate the top frame to a particular site.
> other IE windows. You basically spun them off.
> like this:
> the first filter.
> URL. Here's where you may encounter a problem: there is NO guarantee that
> the URL you end up at is identical to the one you chose to navigate to.
> For example, when I use
> I end up at the URL
> like this:
> each window instead. This ensures you know which IE is important, even if
> it was redirected. For example, do this:
> $ie.Navigate($url);
> $ie;
>> Hi:
>> $ie.Visible = $true
>> Thanks!
>> MG
