Issues - Sound SW & External USB Devices
Fiddlehead50
I have a new Vista Home Premium Laptop (Acer Aspire 7520), purchased about 6 weeks ago. I've come across two problems, and I believe they are related.
First, whenever I hook up a USB device, such as external speakers or headset, as soon as I unplug them and return to the laptop speakers, the sound is lost altogether, and I need to uninstall the sound driver and reboot - which triggers a fix from Microsoft - to restore sound from my laptop speakers. I originally had RealTek sound drivers, but this process, undertaken a few times now, has resulted in a switch to a generic High Definition Audio Device, auto-installed from Microsoft on reboot.
Second, I downloaded SoundTap Recorder. When I tried to enable it, the silence was deafening. Even when I subsequenty disabled the new app, the laptop speakers were silent, and the little megaphone in the taskbar was showing mute, even though I tried to restore sound. So I had to uninstall Sound Tap, and this restored the laptop sound without a system reboot.
The Acer Helpdesk has recommended restoring the system to earlier settings and/or a full factory restore, but with the time (days!) I have invested in setting up my new laptop with various applications, I don't want to take such a drastic and comprehensive approach to the problem unless I am sure it is going to work.
Well, did the sound have issues before or not - if it was working fine then it should work fine again when you revert to a system restore point.
But, I want to know this - you say when you remove USB devices - are any of those devices showing in the "Safely Remove Hardware" icon in your system tray, and if so, are you safely removing them as you should?
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech G15 (gen 2)
    Logitech MX Master (shared)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Well, let's put it this way: as soon as I unplugged the external speakers, the problem arose. Same with the headphones. However, I should do the "safely remove hardware" thing, which I am careful to do with my ipod and other memory-keys. For some reason, I thought I could get away without doing that for speakers and headset.
