issues with the AVp
first of all, this is my first post but I have been following the forum since I got Vista 64 and it has already helped me a lot. So thank you for all your hard work.
I have a problem, and I hope you can help:
I can't reinstall my Antivirus-Software, this is why I believe it could be a Windows related problem:
- When I install it tells me the Windows-Installer doesn't work.
- Whatever I do I can't get rid of the registration files in regedit. It just doesn't let me delete the files "Error deleting the key" (translated)
- there the Antivirus Software has left a file on my harddrive called shellEx.dell which I just can't delete
any thoughts?
Thank you!
    2,83 GHZ QUAD CORE
    ASUS P5Q
    8GB RAM
What antivirus software are you trying to install?
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Western Digital 160 GB IDE
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
pooch
Old Dog
any thoughts?
Thank you!
Hi Antonius, welcome to the forum,
You havent said what make of program this is. Have you tried visiting their web site to see if there is a removal tool?
Alternatively you could try using CCleaner - Home as it might also remove the remnants.
I hope this helps.
Pooch
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Drive #1 - SAMSUNG HD252HJ (250 GB)
    Drive #2 - Hitachi HDT721010SLA360 (1000 GB)
    Drive #3 - SAMSUNG HD250HJ (250 GB)
    Drive #4 - SAMSUNG HD103UJ (1000 GB) External eSATA
    Enermax Chakra
    Easy Line Laser Mouse
    Standard
    I have also used Fedora, Suse, Ubuntu Linux
    And all other Windows from 95 to date except ME
pooch
Old Dog
Back after a small break and I'm already to slow!! I'll be quicker next time :p
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
thank you for your replies
1) I tried various registry-cleaing softwares they all identify the problem but are unable to delete the registry entry
2) it is kaspersky internet security 2009 and I could not find any removal tool
3) I had to remove the programme manually (not using the windows installer) as the program was in some way corrupted and did not "let" me deinstall it
I removed the program from my sistem apart from the shellEx.dll file (any ideas there?) which is impossible to delete (I tried renaming, deleting software etc.) and the registry entries
    2,83 GHZ QUAD CORE
    ASUS P5Q
    8GB RAM
#8
I tried the KIS uninstaller, Windows still thinks it's there and now the installation doesn't start due to a errormessage saying that the disk is currupted...
I don't understand why it has to be SO hard to get that software off my system...:confused:
    2,83 GHZ QUAD CORE
    ASUS P5Q
    8GB RAM
pooch
Old Dog
Try cleaning again
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
#10
same problem.
- I can't get rid of the Kaspersky registry keys
- I can't reinstall the software because it tells me there is a problem with the windows installer (I tried solving the problem by updating the windows installer)
    2,83 GHZ QUAD CORE
    ASUS P5Q
    8GB RAM
pooch
Old Dog
same problem.
what is the message??
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
#12
the error message in its german original form:
"Auf den Windows-Installer Dienst konnte nicht zugegriffen werden. Dies kann auftreten wenn der Windows-Installer nicht richtig installiert wurde. wenden sie sich an den Support um weitere Unterstützung zu erhalten."
translated:
"the Windows installer appication could not be accessed. This can happen when the Windows-Installer was not properly installed. Consult Support for further help."
I doubt it has anything to do with my software-CD as it worked perfectly the first time....
    2,83 GHZ QUAD CORE
    ASUS P5Q
    8GB RAM
pooch
Old Dog
translated:
have a look here;http://www.vistax64.com/vista-insta...ows-installer-service-vista-all-versions.html
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
pooch
Old Dog
that also didn't work
Ok lets try doing this from another angle,
Go to Start, Start Search, type msconfig select msconfig.exe, accept the UAC, select Startup, remove the tick from Kaspersky. select Services, again remove the tick from Kaspersky.
Restart the computer, try again to delete the shellex.dll and the other bits that still remain
Try the CCleaner again as it might remove things you cant see
Try the kaspersky removal tool again
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
#16
I already removed the tick from kaspersky, and there was no kaspersky in services.
I still can't delete the shellEx.dll file, every time I try it tells me
"You need authorization to continue this process"
Repeat Cancel
I click repeat it tells me the same, and so on and so on and so on until I click cancel.
I cannot edit or rename the file either.
    2,83 GHZ QUAD CORE
    ASUS P5Q
    8GB RAM
pooch
Old Dog
Repeat Cancel
Right click on the file select Properties, Security, edit, your user name and try to change the Permissions
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
