The111
Hi, I'm new to Vista and a few things are bothering me at the moment:
1) If I set my current folder to "list" view and then go and "apply current settings to all folders"... in XP this would do just that: put every single folder on all my disks in "list view" by default. Unfortunately, Vista still seems to try to display what it considers "media folders" as "tile view" until I manually change each one to "list" view. Do I have any way to set them all to list as I intend?
2) When I turn on the "status bar" in flie explorer, it does indeed show the status bar, and if I click on a file it will show the size of that file in the status bar. In XP however, if no file was selected it would show the combined size of all the files in the folder, and if I selected a specific group of files it would also show their combined filesize. Neither of these seem to show up on the status bar in Vista.
3) Is there any way to prevent folders from "lighting up" as you move the mouse over them? I would call this "pre-select highlight" after a similarly named (and similarly disliked) feature in a CAD program I use.
4) This one is kind of stupid, but sometimes due to all my external drives, I like to have a long (tall) but narrow vertical window, where the folder names just fill up the width. If I scroll down the list and either delete or rename something, the whole list apparently disappears, but it has actually just scrolled off the screen somehow, even though there is no scrollbar present. A simple F5 will fix things but this still sucks.
Thanks!
Thanks!
- Intel Core 2 Duo E6400
- ASUS P5W DH Deluxe
- 4GB DDR2 800
- Graphics Card(s)
- NVIDIA 8800GT
- Bgears b-Enspirer
- Case
- Antec 1200
