Solved Java FX 2.1.0
tom982
٩(͡๏̯͡๏)۶
Hello typo and welcome to the forums :party:
Java FX is used in developing rich internet applications (RIA). If you're not a developer, then you don't need it :)
You will need JRE 7 to run Java applications. The latest version (7u4) can be found here:
JRE 7u4 Downloads
Tom
"If you're not a developer, then you don't need it :)"
I Thought so. I already removed it yesterday. And so far I have no prob without it.
