Keyboard cut and paste
G
Gary Ash
Is it possible to bind clipboard stuff like copy, cut, and paste to the
keyboard?
Thanks
Gary
J
Jeff
> keyboard?
> Thanks
> Gary
Gary,
If you mean copying and pasting text in the PowerShell console, then
yes, it is possible. Hit Alt+Space to bring up the console menu, then
type 'E' to bring up the 'Edit' menu and then 'k' to start copying or
'P' to paste the text in the clipboard to the console. In 'copying'
mode, you just use the arrow keys while holding down the shift key to
select text, and hit Enter to add the selection to the clipboard.
I use the keyboard to paste text in the console all the time; I have
even started using the Alt+Space,E,P key sequence in other
applications, sometimes with unhappy results. The method to select
text in the console is really only convenient if you just don't have a
mouse; I rarely use it.
All of this behavior is identical in the regular cmd.exe console.
If this doesn't answer your question at all, I'm sorry.
Jeff
G
Gary Ash
Thanks for answering back. What I'm really looking for is more of a Ctrl+V,
Ctrl+X sort of thing
4NT the command shell from JP Software can do a Ctrl+V. I was sort of hoping
to get better scripting and command line editing
"Jeff" <[email protected]> wrote in message
news:[email protected]
>> keyboard?
>> Thanks
>> Gary
> Gary,
> Jeff
S
Shay Levi
Check PowerShell+ from Shell Tools.
It's a true PowerShell console embedded in a rich and intuitive user interface
and is FREE for non-commercial use.
http://www.powershell.com/plus/index.html
Shay Levi
$cript Fanatic
http://scriptolog.blogspot.com
> Ctrl+V,
> hoping
>>> the keyboard?
>>> Thanks
>>> Gary
>> Gary,
>> then type 'E' to bring up the 'Edit' menu and then 'k' to start
>> copying or 'P' to paste the text in the clipboard to the console. In
>> 'copying' mode, you just use the arrow keys while holding down the
>> shift key to select text, and hit Enter to add the selection to the
>> clipboard.
>> a mouse; I rarely use it.
>> Jeff
H
Hal Rottenberg
tomd62
Is this some sort of fetish? Why cant Microsoft use simple cut and paste shortcuts for consoles? It's been 20 years now and still you have to use some non-standard method for only the console, every other app on Windows allows for Ctl-X,C,V for Cut/Copy/Paste.:rolleyes:
L
Larry__Weiss
I had a boss once who called that sort of thing a "historical imperative".
- Larry
K
Karl Mitschke
Hello tomd62,
It's a console, not a Windows App :)
Stuck in the back of my memory, there is a Posh Console (I *BELIEVE* written
by Jaykul), that should allow cut & paste
Karl
http://unlockpowershell.wordpress.com/
L
Larry__Weiss
Karl Mitschke wrote:
> Hello tomd62,
> written by Jaykul), that should allow cut & paste
Consoles can allow copy and paste, you just have to enable it,
and do it differently from Windows apps.
http://www.tech-recipes.com/rx/249/cmd-copypaste-between-window-and-command-consoledos-program/
- Larry
K
Karl Mitschke
Hello Larry__Weiss,
>> Hello tomd62,
> Consoles can allow copy and paste, you just have to enable it, and do
> - Larry
Well, yeah, but the OP wants to do a <CTRL><V> and <CTRL><C> :)
Karl
L
Larry__Weiss
<CTRL><C> is taken already.
If I could change history, I'd encourage a keyboard that had keys labeled "Copy"
and "Paste".
- Larry
