Keyboard intermittently stops working
threedog
I just converted to Vista Enterprise with and IBM laptop and docking station. I keep losing my external IBM keyboard, 3 or 4 times a day. If I pull out the USB plug and put it back in to reset it my keyboard starts working again.
I've updated the latest driver on the IBM website but still have the problem.
Anyone seen anything like this?
H2SO4
A bit of a numpty
It is probably a hardware issue, especially if you see the same problem when the machine is booted to safe mode and left to run overnight.
Does it make a difference if you pull out all other USB devices and run for 24h that way?
What about if the external keyboard is plugged into a USB socket on the laptop itself instead of the docking station?
Ayporos
know-it-all
H2SO4 I get the same problem on my desktop PC from time to time.
It ain't a hardware error... its a vista/USB driver error.
as of today ive still been unable to find a proper explanation/fix for it though.
    Me, myself and I
    Intel Core 2 Duo E 8500
    Asus P5Q3 DELUXE
    4x 1GB DDR3
    Asus GeForce 9800GTX+
    SoundBlaster X-Fi X-treme gamer
    Samsung Syncmaster 226BW
    1680 x 1050
    1x 250gb SATA
    4x 1TB SATA in RAID5
    CoolerMaster 650Watt
    CoolerMaster 690
    4x 140mm, 3x 120mm, 1x 80mm casefans
    Logitech G5
    Razer Lycosa
    ADSL 12mbit/s
    My other OS is a Linux =)
Ayporos
know-it-all
because I didn't have the problem in XP but I have it now in vista?
    Me, myself and I
    Asus P5Q3 DELUXE
    4x 1GB DDR3
    1680 x 1050
    1x 250gb SATA
    CoolerMaster 690
    Logitech G5
    Razer Lycosa
    ADSL 12mbit/s
H2SO4
A bit of a numpty
Your problem may not be the same as the OP's :)
Personally, I don't believe there's enough info to be certain of what the cause is in the OP's case. That's why a bit of testing might be useful.
