Keyboard Layout under Command Prompt
B
bkortleven
The pc localisation for the machine is Belgian, language is dutch. Keyboard
layout is Belgian azerty.
When we start an older dos application under the command prompt, we only get
the us qwerty layout.
We tried adding keyb be (like it used to be pre-vista), kb16 (read in topic
item
http://www.microsoft.com/communities/newsgroups/en-us/default.aspx?dg=microsoft.public.windows.vista.general&tid=1fedba88-19c8-4c18-b972-bddcc6a7555a&cat=en_US_9CA88DDB-D18D-FA0E-A366-6E527B0FBA67&lang=en&cr=US&sloc=en-us&m=1&p=1),
but to no solution. It doesn't recognise either 'keyb' nor 'kb16' as a valid
command.
Anyone knows how to solve this, or where the kb16 command can be found?
Thanks!
A
Andrew McLaren
"bkortleven" <[email protected]> wrote ...
> valid
> command.
Bonjour ... pardon, Goede Dag :-)
On 32 bit Vista, KB16.COM should be in the %SystemRoot%\System32 directory,
usually C:\Windows\System32. First, verify that the files exist on your
machine (they are installed by default):
C:\Windows\System32\KB16.COM
C:\Windows\System32\Keyboard.sys
C:\Windows\System32\Country.sys
Next, test that KB16 runs okay, by entering the command:
C:\Windows\System32\KB16 BE,850,C:\Windows\System32\KEYBOARD.SYS
It should return to a command prompt, with no messages (error, or
otherwise).
To activate KB16 for a DOS application, you need to run it in the same
instance of the NTVDM ("NT Virtual DOS Machine") as your application. On
Windows NT (including 2000, XP and Vista) a DOS application takes its
startup environment from the files C:\Windows\System32\Config.NT and
C:\Windows\System32\Autoexec.NT. So, to activate a code page for a DIOS app,
add the code page commands to C:\Windows\System32\CONFIG.NT and
C:\Windows\System32\AUTOEXEC.NT, the same as you would to C:\CONFIG.SYS and
C:\AUTOEXEC.BAT on a DOS machine.
In CONFIG.NT add to the end of the file:
COUNTRY=032,850,C:\Windows\System32\COUNTRY.SYS
In AUTOEXEC.NT add to the end of the file:
Now to test, open a Command Prompt.
Then run the command "command.com". This will start an instance of the
MS-DOS Command processor.
Run the command "edit", to start the DOS editor.
Try typing in a few words in Edit, to see if the new Belgian keyboard is in
effect.
If it doesn't work in Edit, then review the above steps carefully.
If it works in Edit, but doesn't work in your old DOS application, then the
app is not getting its Code Page info from DOS. It may be storing it in a
config file, or the like.
If it works in your application - hey, problem solved! :-)
Hope it helps; let us know how you get on.
Met vriendelijke groet!
Andrew McLaren
amclar (at) optusnet dot com dot au
L
Livinus
Bedankt, Dit werkt perfect.
Thanks, it is a great relief. Those old fashioned DOS programs are still
very helpfull. Wouldn't like to miss them.
Livinus, Elgetex
> > valid
> > command.
> otherwise).
> effect.
> Andrew McLaren
