Keyboard skipping letters
A
Amanda
Father in law's keyboard was skipping letters. (says when they are typing
along, hunt & peck, then look up at the screen, letters are missing.)
His is a new e-machine, the keyboard came new with it. Windows Vista Premium.
He bought a new keyboard, (more ergonomic, no because of the problem) and
says the new keyboard also skips.
Are there actually drivers and updates & things for keyboards? What should I
check first to verify if it is a system problem versus defect in hardware
versus operator error? THANKS
Amanda B
J
JerryM
The computer should still be under warrantee,
Return it to the store for a replacement.
Jerry
"Amanda" <Amanda@xxxxxx> wrote in message
news:39B4D010-C306-4C9C-914F-885C2441BBAF@xxxxxx
> Premium.
> I
> Amanda B
R
R. C. White
Hi, Amanda.
Is he a fast typist? Maybe he's getting ahead of the hardware, especially
if that is a wireless keyboard.
I'm moderately fast (~60 WPM) and often get ahead of my Microsoft Wireless
6000 keyboard. Even when I'm not typing fast, I often look up and see that
"what is this" has been interpreted as "what I sthis" - because WLM's spell
checker saw the space before the "s" following the "i" and "corrected" it to
a capital "I" for me. :>( Often, too, I'll see "teh" convert to "the"
right before my eyes.
Yes, and they are very hardware-specific. Can you tell us the make and
model of his keyboard(s)? Generic drivers are built into Vista, and the
specific driver for the first keyboard should have been included with the
e-Machine computer. The new keyboard should have come with a CD or other
media containing the driver for it if it needed a special one.
Of course, if it is a wireless keyboard, the solution may be as simple as
dying batteries, either in the keyboard itself or in the sending unit. Or
with interference from other objects between the computer, the sending unit,
and the keyboard.
RC
R. C. White, CPA
San Marcos, TX
rc@xxxxxx
Microsoft Windows MVP
(Running Windows Live Mail 2008 in Vista Ultimate x64)
> Premium.
> I
> Amanda B
D
Dominic Payer
Is it a Bluetooth or wireless keyboard? If so, make sure the dongle at the
computer end has a clear and short line of sight to the keyboard (and mouse
if relevant) since the problem might simply be poor communication because
the signal is blocked. Don't put the wireless or Bluetooth dongle in the
back of the computer.
Watch and see if he is pressing the keys firmly enough. Keyboards differ and
the new ones may be less sensitive than anything he is used to.
There are drivers for keyboards and mice, but they make the special function
keys work and provide more advanced customisation of the keyboard. For basic
keyboard use they are not essential. Look on the underside of the device and
note the manufacturer and model number, then visit the manufacturer's
website and see what drivers they offer. Driver disks should have been
supplied with the keyboard, but could have outdated or buggy versions of the
drivers, so it is always advisable to get the latest drivers for anything
from its manufacturer's site.
> Premium.
> I
> Amanda B
A
Amanda
Yes, he took the one back to the store, they said there was nothing wrong
with it. I am going to see him today, I'll see how he types, what the brand
name is etc.
I thought it was just a dirty keyboard, until the new one also did it.....
Amanda B
> Jerry
> > Premium.
> > I
> > Amanda B
A
Amanda
He is definitely not a fast typist. I'll go over to see him and watch what he
is doing, as well as note the specific mfg etc.
Maybe I should look at the control panel properties for sensitivity.
Amanda B
"R. C. White" wrote:
> Hi, Amanda.
> and the keyboard.
> RC
> R. C. White, CPA
> San Marcos, TX
> rc@xxxxxx
> > Premium.
> > I
> > Amanda B
A
Amanda
I'm pretty sure it isn't wireless. On my own computer, I solved several
problems just by moving that little dongle thing. I'll take a closer look at
his setup, I just wanted a few options before I do. Did'nt really think
drivers could have an effect. I'll get more info, then go from there, thanks!
Amanda B
> > Premium.
> > I
> > Amanda B
A
Amanda
#8
Nandika?
I have not found a solution. It could be a CPU usage problem though, I had
not checked on that. The keyboard doesn't seem to skip all the time, so it's
hard to track it down.
Amanda B
"nandika" wrote:
> I have the same problem (keyboard skipping letters)... I run Vista
> Ultimate with all the updates.
> I have a Toshiba Laptop, so the keyboard is not wireless/bluetooth etc.
> It should also be fast, but I didnt edit anything in the bios. I didnt
> have this problem with XP with this laptop, but I also didnt have this
> problem with my older sony vaio with vista homepremium.
> I've noticed that it only happens when my CPU usage is higher or 100%.
> Its very annoying... anyone found a solution already?
> nandika
#10
I'm having the same problem on my HP. It appears to be Vista related as many people with different computers are having the same problem. Any solutions yet?
k0rc
I had this exact problem on my wife's HP nx9600 laptop after I installed a new HDD and loaded the OS (XP Pro in this case) from scratch. I went to the HP download/drivers site and found the keyboard and pointing device driver. The file was dated 3-years old but the skipping letters problem immediately went away after installing this driver and doing the requisite reboot.
