KME Inc. - Input - USB Human Interface Device
I recently received this as an optional update in Windows Updates.
Because I had just installed a new mouse (Manhattan) I thought maybe I should install this update. Ever since installing it I've had little glitches in performance. For instance, when I open something the little blue circle goes around forever before it opens. These items used to flash right open previously. I did go to Device Manager and find this item and I really think I'd like to get rid of it. Would it be best to just use the "roll back driver" option and will it be safe to do this?
As you can tell I'm pretty much in the dark here and would like some advice about how to handle this. This is the first time I have ever installed an optional update and I don't think I'll be doing it again.
I have Vista Home Premium SP2.
    Dell DXP061
    1.87 gigahertz Intel Core 2 Duo
    High Definition Audio Device
    NVIDIA GeForce 7300 LE DELL E207WFP [Monitor] 20"
    SAMSUNG HD321KJ [Hard drive] (320.07 GB)
    DSL
    Avast Internet Security 7 / Malwarebytes Pro / WinPatrol Plus / Secunit PSI /
Try uninstalling the Mouse and reboot.
    Acer 5315 with upgraded CPU and ram.
    Intel T7500
    Intel
    2 gig
    Integrated
    onboard
    WD Sata2 500 gb
    Stick mouse
    20 meg line/ 15700kbps sync
    Sky
