Laptop will not connect
60
Hi, I have just bought a second hand laptop.
Problem is when I try to connect it to my home network via the on board wifi it keeps on saying that the security key does not match the security key for this network. After I don't know how many attempts at re-entering the key it will connect.
But when I turn the laptop of and start it up again it tells me that the key does not match again.
I have set it to save the config, but it either doesn't or there is something else wrong.
The laptop is an Acer 5050
Windows Vista home Premium.
Could it be a driver problem ?
My other laptop connects first time everytime.
Thanks for any help.
Brian.
    ME
    AMD 64 X2 5200+
    ASUS M2N-E SLI
    4 GB CORSAIR CM2X 6400 C5 800MHZ
    PNY Geforce 980GTX+ 512MB DDR3
    AUDIGY 2
    ViewSonic VA2216w 22" wide screen
    1680 x 1050
    2 X SAMSUNG SATA 500GB
    1 external usb 500GB
    650 WATT
    IntellieMouse Optical
    Logitech G15
    2mb
2,456
Location
NY USA
Brian.
Nope not a driver, can you try connecting with the encryption turned off so that you dont need to know the username and pword?
Could you also give us some info about your network setup?
Ken
    Dell Inspiron E 1405
    2@2.0
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
60
The network is a Netgear DG834 v4 and a Netgear WG602 v2.
3 desktops connect via cable.
IBM laptop is wi-fi
Ha, the Acer has just connected. Will disconnect and see what happens.
Connected up staight away.
But if I turn the laptop off and restart it wont.
Brian.
    ME
    AMD 64 X2 5200+
    ASUS M2N-E SLI
    AUDIGY 2
    1680 x 1050
    650 WATT
    Logitech G15
    2mb
60
OK after putting ticks in all sorts of boxes one at a time and tacking them out again I have sorted it.
The Netgear access point is set not to transmit ssid.
On the Acer laptop I found a box that says "Connect even if ssid is not transmitted"
so put a tick in it.
Shut down laptop restart and it connects everytime.
Thank you this is now solved.
Brian.
    ME
    AMD 64 X2 5200+
    ASUS M2N-E SLI
    AUDIGY 2
    1680 x 1050
    650 WATT
    Logitech G15
    2mb
