LCD Refresh out of range
T
Terry
I have a couple of old LCD monitors (Samsung SyncMaster 170MP and SGI
1600SW). Niether seem to work with Vista - all I get is a black screen. My
graphics card is a ATI Radeon X1600Pro. When I boot - the screen refresh goes
out of range. My Monitor is set to Default Monitor. I can neither change the
refresh rates nor attempt to add a monitor driver.
The monitors work in safe mode (VGA) and when I disable the video card to
VGA mode.
How can I set the Default Monitor refresh rate to 60Hz? Is there another
solution?
=?Utf-8?B?QmV0YSBUZXN0ZXI=?=
Out of Rage - 36.3Khz / 34 Hz - ATI X1900XTX
I am experiencing the same problem using the ATI X1900XTX. I get all the way
thru the installation of Vista RC-1, and then the screen turns black.
I then reboot the system and perform the repair from the installation Disk,
and it is unable to resolve the error. My screen displays the error:
Out of Range - 36.3Khz / 34Hz
At this point I am unable to continue. However, the machine works
flawlessly on Win XP 64 Bit O/S.
Any ideas on how to resolve these issues with ATI Cards?
Regards,
Chad
> VGA mode.
> solution?
=?Utf-8?B?VGVycnk=?=
I solved my original problem by updating the BIOS -- it turned out to be a
problem (if I recollect correctly) with the memory addressing for PCI-E. No
problem with the graphics card itself. Hope this works in your case.
> Any ideas on how to resolve these issues with ATI Cards? My monitor is the
> Sony 19 Xbrite LCD.
> Regards,
> Chad
> > VGA mode.
> > solution?
