LEGO Star Wars caused BSOD after it crashed
146
I decided to install LEGO Star Wars on my vista and try to fix the problem with it crashing when I try to start it up. But this time, I got something so unexpected, and something utterly terrifying (Yes, I value my computer so much).
I tried to change the screen resolution on the game to the highest possible (1660xsomething) and the game minimized and the "LEGO Star Wars has stopped working" message came up. Since I couldn't see my cursor, I hit the spacebar to click "Close Program".
After that, the BSOD flashed on and told me I got a "bad header" or something, I can't excactly remember. It was there for like 2 seconds and then the computer restarted itself. It didn't boot, so I flicked off the power switch and turned it back on and now everything is back to normal.
I tried running the program again and this time it just crashed when the menu appeared. Nothing happened after that. This has always happened whenever I tried to start the game.
I also tried going through the Program Compatibility Wizard and ran it in XP Service Pack 2, but for some reason the computer restarted itself again.
EDIT: BSOD report and health check are attatched.
Is Vista . . .
- x86 (32-bit) or x64 ? 32-bit
- the original installed OS on the system? Yes.
- an OEM or full retail version? OEM.
- What is the age of system (hardware)? About 5 years.
- What is the age of OS installation (have you re-installed the OS?) About 5 years too, and no.
    Dell Inspiron 530
    Acer
    1920x1080
    Dell USB Mouse, Logitech Wireless Mouse or Windows Optical
    Dell/Logitech
    Thank you for everything you've done for me in the past years. I'm sorry that games require much more than you're capable of, but you'll never be forgotten as my first personal computer <3
richc46
Staff member
20,105
Location
Fairfield County, CT
The most imporant report, the minidmp, is not present. Please follow directions carefully and post again.
146
What's the minidmp?
    Dell Inspiron 530
    Acer
    1920x1080
    Dell/Logitech
richc46
Staff member
20,105
Location
146
    Dell Inspiron 530
    Acer
    1920x1080
    Dell/Logitech
richc46
Staff member
20,105
Location
You zip it up to us.
146
Right, I looked in C/Windows and found the Minidump folder but it's empty?
    Dell Inspiron 530
    Acer
    1920x1080
    Dell/Logitech
richc46
Staff member
20,105
Location
#8
