Less Ugly Way to Filter Data Into a Collection?
P
Patrick A
I have a form where buttons are added by code. I want to filter the
buttons on the "Show" column in my data source unless the user has
indicated otherwise, which sets MyGlobals.ShowAllButtons = True.
The code below works, but I can't believe there is not a better way.
I have tried to filter the Binding Source a variety of ways,
Me.QRY_ButtonsBindingSource.Filter = "Show = True"
Me.QRY_ButtonsBindingSource.Filter = "Show = 'True'"
Me.QRY_ButtonsBindingSource.Filter = "Show =" & True
Me.QRY_ButtonsBindingSource.Filter = "Show =" & "'True'"
but with no results.
Am I totally misunderstanding the concept of "where and how" to
filter, or is there an easier way?
Thanks,
Patrick
Me.QRY_ButtonsTableAdapter.ClearBeforeFill = True
Me.QRY_ButtonsTableAdapter.Fill(Me.L55TimerDataSet.QRY_Buttons)
Dim Row As Integer = 0
Dim ButRecds =
L55TimerDataSet.Tables("QRY_Buttons").AsEnumerable '.Select("Show =
True")
Dim sortedButRecds = From a_row In ButRecds Select a_row
'Get values - labels, meanings, colors, etc. from the DB.
For Each a_row In sortedButRecds 'Iterate through the
collection.
If MyGlobals.ShowAllButtons = False Then
If a_row!show = True Then
Row = Row + 1 'Increment up.
NewButton = New MyButton(Me) ' Sets a new
button
Me.Panel1.Controls.Add(NewButton) 'Adds the
new button to the form.
NewButton.butID = a_row!TimerID.ToString
NewButton.Name = (a_row!Position) 'Pull the
TimerPos from DS and use it as a tag.
NewButton.Text = (a_row!Label) 'Pull the
butLabel from DS and use it as text.
NewButton.butLabel = a_row!Label.ToString '
NewButton.butNarr = a_row!Narrative.ToString
'Read the Work Description from the DB.
NewButton.butDispCM = a_row!
ClientMatter.ToString 'Read the Cli/Mat from the DB.
NewButton.butTask = a_row!Task.ToString 'Read
the Task Code from the DB.
NewButton.butAct = a_row!Activity.ToString
'Read the Activity Code from the DB.
NewButton.butDisplaySpan =
TimeSpan.FromSeconds(a_row!daySpan)
NewButton.butLoc = MyGlobals.CurrentLoc
NewButton.BackColor = Color.FromName(a_row!
Color) 'Read the color of the button
NewButton.butShowMe = a_row!show ' Read the
Show or Don't Show value for the button
' Set up the Right-Click menu
NewButton.ContextMenuStrip = cmTimeButs
oTimeSliceCollection.Add(NewButton,
a_row("TimerID").ToString)
End If
Else
NewButton = New MyButton(Me) ' Sets a new button
Me.Panel1.Controls.Add(NewButton) 'Adds the new
button to the form.
NewButton.Text = (a_row!Label) 'Pull the butLabel
NewButton.butNarr = a_row!Narrative.ToString 'Read
NewButton.butDispCM = a_row!ClientMatter.ToString
NewButton.butTask = a_row!Task.ToString 'Read the
NewButton.butAct = a_row!Activity.ToString 'Read
TimeSpan.FromSeconds(a_row!daySpan) 'Read this day's seconds
NewButton.BackColor = Color.FromName(a_row!Color)
'Read the color of the button (by name)
NewButton.butShowMe = a_row!show ' Read the Show
End If
Next
C
Chris Dunaway
> Thanks,
> Patrick
>             Dim ButRecds =
> True")
>             'Get values - labels, meanings, colors, etc. fromthe DB.
> collection.
> button
>                     End If
>                 Else
>                     Row = Row + 1   'Increment up..
> button to the form.
>                     NewButton.butID = a_row!TimerID..ToString
>                 End If
>             Next
What is the Show column's data type? It seems like your first example
should work, since the Filter property is just a string.
Chris
P
Patrick A
Chris,
Thanks for your reply. It's a Yes/No data type with a format of True/
False.
MsgBox(Me.QRY_ButtonsBindingSource.Filter.ToString) returns Show=True
Patrick
> > Thanks,
> > Patrick
> >             Dim ButRecds =
> > True")
> > collection.
> > button
> >                         NewButton.butDispCM =a_row!
> >                         NewButton.BackColor =Color.FromName(a_row!
> >                         NewButton.butShowMe =a_row!show ' Read the
> >                     End If
> >                 Else
> > button to the form.
> >                 End If
> >             Next
> Chris- Hide quoted text -
> - Show quoted text -
