Line-in to sound card - no sound, no volume display
Phonograph player into line-in on SigmaTel sound card has no sound. This
worked w/ XP, stopped after Vista installed. Speakers work fine on everything
else.
Windows Vista help says go to speakers properties, & lin-in is mute by
default. (Help picture shows Volume control,Phone Line,Line-in, Aux &
Micrphone; but when I go there mine only displays the volume control & the
other items are midssing, so I can't unmute. I can't record anything.
W
Wandering
If the phonograph player is just a turntable meant to be plugged into a
stereo system the output will be far too low for an computer input. You will
either need to plug it into an amplifier system with a "line out" first and
then plug that into you computer, or obtain an inline amplifier that
duplicates that function.
"JRW" <JRW@xxxxxx> wrote in message
news:53656E4E-AB65-499B-BCD8-71F59391BAB5@xxxxxx
> everything
> else.
T
TimboTen
I had a sound problem with my onboard SigmaTel audio following an upgrade to
Vista. In the end I updated the driver for SigmaTel audio for my motherboard
from the Intel site and it solved my problem. Just one of the XP to Vista
bugs! Hope this helps you.
TimboTen
> else.
J
Thanks for your reply - it sounded like the answer, so I downloaded the
latest SigmaTel driver from Intel, but it didn't work. When I try to check
SigmaTel through the Control Panel, it says the driver is "inaccessable. Make
sure it is installed and enabled." Checking for the line-in connection, it
says Digital Input Device (SPDIF): High Definition Audio Device is working
but not plugged in (it is, of course, & was working before Vista.) It also
says it's a Microsoft driver, not Intel. Did it replace & disable the Intel
driver? My Intel board is a D946GZIS.
> TimboTen
> > else.
1
I had this same issue and tried all the things listed on just about every website that had this issue - new driver wouldn't work, etc. Everything indicated the line-in was working, but I couldn't hear anything..there was no option for mute, etc.. in the volume control panel. I finally found this from the sound card webpage:
Sound Blaster How-To: Learn more about the X-Fi Entertainment Mode with this beginner's guide
Under Entertainment Mode, I chose the beginner and discovered there was a place other than the volume control area to do things. Go to start>programs>creative>sound blaster x-fi>creative console launcher
make sure you're in Entertainment Mode (that's the only mode mine has); run you're mouse across the bottom icons to find the "mixer" option and click it - check the box next to line-in - you will now have sound!!!
