live mail desktop blocks attachments
search online- no answer
i cannot open the attachments *with the "save attachemnt" in "File"
unclickable (grayed out)*
using windows live mail desktop with a hotmail account
vista ultimate SP1
wifi connection
and no anti virus (NOT AVG nor norton)
i've unchecked the "dont allow attachments...." in safety options
and unchecked the "block image..." in teh same menu
also lowered the safety level to low...
i CANNOT find what is still missing
HELP PLZ
I
Ildhund
From Help:
"Windows Live Hotmail doesn't support the following file types. Your
operating system, firewall, or other software may also cause
additional file types to be blocked.
..ade .adp .app .asp .bas .bat .cer .chm .cmd .com .cpl .crt .csh
..exe .fxp .hlp .hta .inf .ins .isp .its .js .jse .ksh .lnk .mad .maf
..mag .mam .maq .mar .mas .mat .mau .mav .maw .mda .mdb .mde .mdt
..mdw .mdz .msc .msi .msp .mst .ops .pcd .pif .prf .prg .pst .reg
..scf .scr .sct .shb .shs .tmp .url .vb .vbe .vbs .vsmacros .vss .vst
..vsw .ws .wsc .wsf .wsh
If it's one of these, you'll have to ask the sender either to zip
the files before sending, or possibly just change the extension to
..txt.
Noel
"Uri" <Uri@xxxxxx> wrote in message
news:16A5CC0A-D82D-4C6A-95FC-C883CC2B6717@xxxxxx
> "File"
> vista ultimate SP1
> wifi connection
> HELP PLZ
G
Gary VanderMolen
Or use a mail provider with fewer restrictions. :-)
Gary VanderMolen, MS-MVP (Mail)
"Ildhund" <jnllb@xxxxxx> wrote in message news:uDGdPjraJHA.796@xxxxxx
> From Help:
> "Windows Live Hotmail doesn't support the following file types. Your operating system, firewall, or other software may also
> cause additional file types to be blocked.
> .ade .adp .app .asp .bas .bat .cer .chm .cmd .com .cpl .crt .csh .exe .fxp .hlp .hta .inf .ins .isp .its .js .jse .ksh .lnk .mad
> .maf .mag .mam .maq .mar .mas .mat .mau .mav .maw .mda .mdb .mde .mdt .mdw .mdz .msc .msi .msp .mst .ops .pcd .pif .prf .prg
> .pst .reg .scf .scr .sct .shb .shs .tmp .url .vb .vbe .vbs .vsmacros .vss .vst .vsw .ws .wsc .wsf .wsh
> If it's one of these, you'll have to ask the sender either to zip the files before sending, or possibly just change the
> extension to .txt.
> Noel
> "Uri" <Uri@xxxxxx> wrote in message news:16A5CC0A-D82D-4C6A-95FC-C883CC2B6717@xxxxxx
>> vista ultimate SP1
>> wifi connection
>> HELP PLZ
J
Here's a workaround to use until you solve it:
Pretend to forward the message but don't send it.
From the menu at the top open 'File-->Save attachments...'
It works!
ju.c
> vista ultimate SP1
> wifi connection
> HELP PLZ
