Local Area Connection cable unplugged???
A
Al
I have a desktop computer on broadband and when I connect to the internet the
red cross turns has been turning into a blue circle to indicate I'm
connected. However for the past week I'm not getting the blue circle, the
red cross remains & when I click on it, it says I'm not connected to any
networks so have clicked on repair and it consistently says I have a Local
Area Connection cable unpluggedl. I have checked all my wiring, nothing is
unplugged, my internet connection is not affected either, all appears to be
working as normal. Can someone tell me what has happened here and whether I
need to worry about it? If I do, can someone tell me what I should do
please. Thanks
R
Robert L. \(MS-MVP\)
Try the following suggestions and please post back with the result.
1. Reset the router.
2. Upgrade the router firmware and NIC driver.
3. Check the network location and make sure it is in private network.
4. Make sure this is not multihomed computer.
Bob Lin, MS-MVP, MCSE & CNE
http://www.ChicagoTech.net
"Al" <[email protected]> wrote in message
news:[email protected]
>the
> is
> be
> I
> please. Thanks
A
Al
Can you tell me what exactly the router is as I don't think I have one. I
have a speedtouch device which the wires are connected to and there are no
buttons or anything like it on the device, just lights which are on and
according to my computer it is functioning properly.
> >the
> > is
> > be
> > I
> > please. Thanks
R
Does the speedtouch device has a new driver?
>> >internet
>> >the
>> > the
>> > any
>> > Local
>> > nothing
>> > is
>> > to
>> > be
>> > whether
>> > I
>> > please. Thanks
A
Al
No it doesn't have a new driver. The only thing I can think of is that I
had updates from Norton & that has messed it up. I found out my IP address
was missing within Norton, found that out & put it in trusted sites, disabled
firewall etc., as well but I still have this red cross and the diagnostics on
the speedtouch say the device is functioning properly and there are no
connectivity problems with this computer. I got other information up which
said local internet had an unplugged cable, hence the red cross, yet I am
connected to my broadband with no problem.
I don't want to dabble too much as if I don't know what I'm doing in case I
lose my internet.
> >> >internet
> >> >the
> >> > the
> >> > any
> >> > Local
> >> > nothing
> >> > is
> >> > to
> >> > be
> >> > whether
> >> > I
> >> > please. Thanks
R
Posting the result of ipconfig /all may help.
> address
> disabled
> on
> which
> I
> lose my internet.
>> > I
>> > no
>> >> >internet
>> >> >the
>> >> > circle,
>> >> > the
>> >> > any
>> >> > Local
>> >> > nothing
>> >> > is
>> >> > appears
>> >> > to
>> >> > be
>> >> > whether
>> >> > I
>> >> > do
>> >> > please. Thanks
A
Al
Connection-specific DNS Suffix . :
Tunnel adapter Local Area Connection* 154:
Media State . . . . . . . . . . . : Media disconnected
Tunnel adapter Local Area Connection* 155:
Tunnel adapter Local Area Connection* 156:
Tunnel adapter Local Area Connection* 157:
Tunnel adapter Local Area Connection* 158:
Tunnel adapter Local Area Connection* 160:
Tunnel adapter Local Area Connection* 162:
Tunnel adapter Local Area Connection* 163:
Tunnel adapter Local Area Connection* 164:
Tunnel adapter Local Area Connection* 165:
Tunnel adapter Local Area Connection* 167:
Tunnel adapter Local Area Connection* 169:
Tunnel adapter Local Area Connection* 176:
Tunnel adapter Local Area Connection* 177:
Tunnel adapter Local Area Connection* 178:
Tunnel adapter Local Area Connection* 181:
Tunnel adapter Local Area Connection* 182:
Tunnel adapter Local Area Connection* 185:
Tunnel adapter Local Area Connection* 188:
Tunnel adapter Local Area Connection* 191:
Tunnel adapter Local Area Connection* 193:
Tunnel adapter Local Area Connection* 194:
Tunnel adapter Local Area Connection* 196:
Tunnel adapter Local Area Connection* 197:
Tunnel adapter Local Area Connection* 198:
Tunnel adapter Local Area Connection* 200:
Tunnel adapter Local Area Connection* 201:
Tunnel adapter Local Area Connection* 202:
Tunnel adapter Local Area Connection* 204:
Tunnel adapter Local Area Connection* 205:
Tunnel adapter Local Area Connection* 206:
Tunnel adapter Local Area Connection* 207:
Tunnel adapter Local Area Connection* 212:
Tunnel adapter Local Area Connection* 213:
Tunnel adapter Local Area Connection* 219:
Tunnel adapter Local Area Connection* 221:
Tunnel adapter Local Area Connection* 222:
Tunnel adapter Local Area Connection* 225:
Tunnel adapter Local Area Connection* 227:
Tunnel adapter Local Area Connection* 228:
Tunnel adapter Local Area Connection* 232:
Tunnel adapter Local Area Connection* 233:
Tunnel adapter Local Area Connection* 234:
Tunnel adapter Local Area Connection* 236:
Tunnel adapter Local Area Connection* 239:
Tunnel adapter Local Area Connection* 243:
Tunnel adapter Local Area Connection* 244:
Tunnel adapter Local Area Connection* 245:
Tunnel adapter Local Area Connection* 249:
Tunnel adapter Local Area Connection* 255:
Tunnel adapter Local Area Connection* 259:
Tunnel adapter Local Area Connection* 260:
Tunnel adapter Local Area Connection* 261:
Tunnel adapter Local Area Connection* 265:
Tunnel adapter Local Area Connection* 266:
Tunnel adapter Local Area Connection* 269:
Tunnel adapter Local Area Connection* 271:
Link-local IPv6 Address . . . . . : fe80::200:5efe:91.108.171.156%280
Default Gateway . . . . . . . . . :
Tunnel adapter Local Area Connection* 272:
Tunnel adapter Local Area Connection* 273:
Temporary IPv6 Address. . . . . . : 2002:5b6c:ab9c::5b6c:ab9c
Default Gateway . . . . . . . . . : 2002:c058:6301::c058:6301
> > address
> > disabled
> > on
> > which
> > I
> > lose my internet.
> >> > I
> >> > no
> >> >> >internet
> >> >> >the
> >> >> > circle,
> >> >> > the
> >> >> > any
> >> >> > Local
> >> >> > nothing
> >> >> > is
> >> >> > appears
> >> >> > to
> >> >> > be
> >> >> > whether
> >> >> > I
> >> >> > do
> >> >> > please. Thanks
H
harvin
hi there
i m having same problem , everything was working fine on my wireless
connected laptop and all of sudden it start showing up as "local area
connection cable unplugged". " unidentified network , limited or no
connectivity but signal strebgth is excellent .
i tried connecting through ethernet cable but same problem .
tried basic thngs like unplugginf everything starting again but same
problem .
Even tried resetting it to the earlier date when everything wasa fine ,
but still its not connecting .
can anyone who knows give any advise
much appreciated
Harry
harvin
harvin's Profile: http://forums.techarena.in/members/213369.htm
View this thread: http://forums.techarena.in/windows-vista-network/1051864.htm
