'Local Connection only' issue is nightmare when no internet exit e
T
Tim Guy
I can see this covered a number of times but I always think the out coming if
because the machine and/or switch/router hasn’t been set up right.. BUT!
I am a network engineer. I know where I’m at when it comes to configuration
BUT I find Vista impossible to work with when the machine isn’t connected to
the internet in any capacity.
If I have to configure routers or SANs, basically anything that doesnt have
some kind of internet connection / exite, I can’t do it with the Vista laptop
because it just will not allow connection unless it can see the internet.
(cross over wired connections are impossible)
Put an XP machine in the same location and it works fine.
Just the other day I had a job to go around and upgrade the internet in a
chain of shops. Hooked the Vista laptop up to Cisco router to configure and
upload a config, couldn’t see it. Everything setup fine.
Put my XP laptop on and tftp’ed and telnet’ed without a problem.
I just can not work out what the problem is, it’s so annoying having to
carry around a 4 year old laptop when your super wizy vista machine can’t do
it.
Basically symptoms are ‘local access’ disabled in the sys tray and no access
what so every.
I had a customer yesterday who has laptops that are disabled via vlan /
switching to be to be allowed to have access to the internet, the users have
to login to a VDI server and access the internet via the terminal servers.
This again doesn’t work. They can ping the workstations but they can’t start
any kind of application session. Again, but a XP machine on with the same
settings, works first time.
ANYONE KNOW HOW TO GET AROUND THIS NIGHTMARE?
Tim
Tim Guy
D
Durrink
We've been running into similar problems here at a major university. Here's
some things we've tried, unfortunately we haven't had much luck with it.
Perhaps it'll help you out.
- Disable IPv6
- Resetting the Winsock catalog
* Note: command 'netsh winsock reset' used
- Resetting the TCP/IP stack
* Note: command 'netsh int ip reset' used
Our problem seems to go in and out every 30 minutes, like yours XP and other
operating systems aren't effected. Our network engineer mentions that the
clients are only talking on their local subnet UDP, no TCP. Very frustrating
issue.
> it.
> what so every.
> Tim
> Tim Guy
I'm with you--I have the SAME problem and a few more. It started about a month ago, and I've had Comcast and other techies from around the globe pulling their hair out! I've learned to go through a few steps that seem, most of the time, to make the Internet come back online, but...it's so completely unpredictable that I've just about given up. It worked beautifully before, but now...it's madness. SOMEONE PLEASE HELP!
Cynthia Dagnal Myron
"Tim Guy" <TimGuy@xxxxxx> wrote in message news:3966E46B-AD2E-40BF-BD43-3801F3A84FF0@xxxxxx
it.
what so every.
Tim
Tim Guy
