Local Network Fix
TiredOfWindows
I posted a couple of days ago about my network access dropping from local & internet, to local, to no connection, after recently upgrading to vista.
I tried every solution othe people have posted on the net but my problem still persisted.
So last night I reinstalled vista and created a restore point after the 1st start-up. I was able to use the internet without interruption for over 5 hrs. Then this morning windows installed updates. After the updates were installed my problem started again. I went ahead and restored my computer to the 1st restore point, and now it is working fine.
My fix to this problem is to not install any updates. I know that it is not the proper fix, but for anyone as frustrated with vista as i am, this is a way to maintain your internet connection.
I am a newcomer to vista, but I found out that this problem has been happening to other for years. I can't understand why microsoft wont fix this problem.
If this post helps anyone else with the same problem, please reply with your story.
    Dell xps 400
    Intel(R) Pentium(R) D CPU 3.20 GHz
    3.25 GB RAM
    Nvidia GeForce 8400 GS
    Sound Blaster X-F1
    37" LCD TV -Protron
    1280X768
    3 MB Broadband- Suddenlink Cable
the problem with not updating vista is it leaves your operating system wide open to attack , thats exactly how conficker spread. An unpatched OS can make your firwall and AV next to useless
why dont you set your updates so they are not automatic , then pick the updates to install , install them one at a time run your pc for a while each time until you find the offending update
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Razer Reclusa
    Logitech G5 Gamer
    8mb
