Local Only Network Connection
3
Okay, I've searched everywhere looking for the fix to the "Local Only" network problem. I've had it a couple days and can't find why I can't get through to the internet. I have disabled IPv6 and tried static ip which I don't think works with my router and some registry fixes and cmd commands. I'm connected through Ethernet wire so it's not a wireless thing. I don't know if I should switch back to XP Pro or maybe buy a new network card. Help please.
ISP: Verizon DSL
Modem/Router: Actiontec Wireless DSL Gateway GT704WGV (2 in 1 type thing Modem + Router)
Network Card: ULi PCI Fast Ethernet Controller
In case you need this:
OS: Windows Vista Home Premium x64
Motherboard: ASRock 939-Socket SATA2 Motherboard
Processor: AMD Athlon 64 X2 Dual Core 4600+ Processor
GPU: nVIDIA GeForce 7900 GT
RAM: Kingston 2 GB 4 X 512 MB
And here is the list from cmd - ipconfig /all
The first is if I set my ip static and the second without it. It seems that if I don't set my ip static then it does not find the router and only finds unidentified network while if I set my ip static it does but I don't believe my router works with setting static ip from the computer. I can also see the other computers linked into my router but just can't access the internet making me believe it is something with the compatibility with the router and Vista. Okay here it is, this is all without IPv6.
STATIC IP:
C:\Users\Chris>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Chris-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : ULi PCI Fast Ethernet Controller
Physical Address. . . . . . . . . : 00-13-8F-6A-9E-EA
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 192.168.1.100(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 0.0.0.0
192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 7:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
Tunnel adapter Local Area Connection* 9:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Link-local IPv6 Address . . . . . : fe80::5efe:192.168.1.100%14(Preferred)
NetBIOS over Tcpip. . . . . . . . : Disabled
NON-STATIC IP:
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration IPv4 Address. . : 169.254.14.231(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Tunnel adapter Local Area Connection* 6:
Link-local IPv6 Address . . . . . : fe80::5efe:169.254.14.231%13(Preferred)
Thanks
22
Hey Chris (I'm assuming your name is Chris from the IP settings...),
Let me be the first to welcome you to Vista X64 forums.
It looks like your router/modem does not have DHCP enabled (or it has a MAC Address filter in place.) Do you know how to edit your router's settings? If not, your ISP may need to do it from their side.
I would like to thank you one hundred ten percent for posting this information from the get-go. It makes our lives so much easier when information is posted in this manner.
It looks like when your computer is set to DHCP/Automatic IP, your router is not giving the PC an IP address. If I'm not mistaken, the 169.254... IP addy is an APIPPA address (Automatic Private IP Address). This address is used by Windows when it is looking for an address but the router it's connected to does not want to give it one.
This either means your router has DHCP disabled, or your router has a "filter" on it baring all but a specific set of MAC Addresses/computer names from connecting to it.
3
Thanks Viper for your help, DHCP is set on as other computers on my network are getting ips assigned and there is no MAC Filter set on the computer, but there are MAC filters on other computers in the network. Can this be a problem? Or is the router not compatible with Vista? I have gotten through once but it was just random after playing around with the network settings on the computer. Once I restarted though it was back to the "Local Only" thing and never has connect back to the internet yet.
Thanks,
Chris
22
Chris,
Do you have a firewall on your Vista machine? Can I also assume that you made sure the CAT5 cable you're using is not bad? It may also very well be a network setting in your Vista machine. I will have to wait until tonight to pull up specific settings to look at, if that's the case, though.
3
No, I have no firewall on my Vista machine that I know of and I have disabled Windows Firewall when I first installed. The cable should be fine unless it went bad in the half hour that I installed Vista from XP, I had no problems in XP. I'm going to look into setting a static ip in my router, then I can see if it is a DHCP problem with Vista as many have problems with. Then I won't have a problem with the router not assigning my ip, right?
bruguiea
1
Hello,
I've been having similar problems, and this worked for this configuration:
* Windows Vista 64
* Atheros AR5007 802.11b/g WiFi Adapter on an HP Pavilion dv5z 1000us laptop
* Netgear WGR614v10 router
I could connect with WEP encryption, but as soon as I would turn on any version of WPA, the laptop would get a new IP with DHCP, but the connection would be marked as "local only".
I solved my case by updating the laptop's wireless card's driver from HP's website. Even though Vista was telling me that the driver was up-to-date and even though I couldn't find any new driver on Atheros' website, I went ahead anyway and used the driver provided by HP.
Hope it helps,
Tony Bruguier
