location is not available help
B
Hi
after receiving windows updates i get this location is not available
c:\windows\system32\config\systemprofile\desktop refers to a location that is
unavailable. it could be on a hard drive on this computer.or on a network.
check to make sure that the disk is properly inserted, or that you are
connected to the internet or your network and then try again. if it still
cannot be located the information might have been moved to a different
location. {i am connected net} it happens when ever i try to d/l anything to
the desktop.
thank you i have vista home premium
D
dean-dean
Try this. Go to C:\Users\(You) and right click on the Desktop folder and
choose Properties. On the Location tab, click on Restore Default. Then go
to C:\Users\Public and do the same for the (hidden) Public Desktop folder.
"Brad" <Brad@discussions.microsoft.com> wrote in message
news:3734AB08-B798-419A-A1F5-59E9249222C8@microsoft.com...
> Hi
> is
> to
> the desktop.
L
landin
"Brad" wrote:
> Hi
> the desktop.
L
landin
Has this issue been resolved? I have a client that is calling me about the
same message. I want to gather as much information about this before I sit
down behind her notebook.
"Brad" wrote:
> Hi
> the desktop.
Spock
We have the same problem. if you discover the solution I'd appreciate very much if you could post it in this forum (in plain english). Thanks a lot. I have Vista home premium as well.
(i hope this helps) I was downloading some files using Bitlord and when i tried looking for them they couldn't be found. I got the same message as the one posted above...
C:\Program Files\BitLord\Downloads\filename refers to a location that is unvailable. It could be on a hard drive on this computer or on a network. Check to make sure that the disk is properly inserted, or that you are connected to the internet or your network, and then try again. If it still cannot be located, the informaiton might have been moved to a different location.
Anyways, all I had to do is go to the folder where my files were supposed to be and click on the "compatibility files" tab and there it was. So everytime I have to access this files I simply go to the folder where my files are supposed to be and click on the tab called "compatibility files" so i can fully see my files. I hope this helps. BYE!!!
CD67
Hi, I'm new to this site, but I was having the same difficulties w/"this location not available". I followed the directions to "restore" defaults" and it has worked so far. I was trying to use an SD Memory Card and the drive wasn't there... after restoring, I put the memory card in the computer and it found the card! :party:Thank you!
Crystal
G
g2dcracker
#8
*The solution is Very simple ..*
Restart your PC and as soon as it reboots press F8 continuosly(on and
off).
It should land you to a screen with many options to start windows like
-starts window normally
* [ S I Z E = \ " 5 \ " ] - L a s t k n o w n g o o d c o n f i g
u r a t i o n t h a t w o r k e d . . [/SIZE]*
Etc Etc..
Choose last known good configuration (using arrow keys ) and press
enter..
Your windows has restore your settings now...
Enjoy..
Hope and wish the solution should work for all..
Best of luck..
If this worked jus say hi on the next reply...
g2dcracker
g2dcracker's Profile: http://forums.techarena.in/members/128494.htm
View this thread: http://forums.techarena.in/vista-help/801087.htm
B
beachlite94
#9
I FOUND OUT AN ANSWER!!
alright it's either one of these.
Go to my computer then C:\Users\
then right click on whatever your username is.
Hit properties
then hit advanced, and hit file is ready for archiving.
I think that's the one that did it, but if that doesn't work,
go to security, and change every one of the users and people in there
, and check every single thing. It will say it denies it a few times
for awhile.
Hope I helped!!
beachlite94
beachlite94's Profile: http://forums.techarena.in/members/171478.htm
