lock a drive and folders
alikhan
3
hi
i have some private data in my pc
and my cosins r visiting us in few days
i dont want to show my private data to them
can i lock my drive or folders by cmd or some other method?
thanks.
V
vanilla
Don't know if this will work or not ... just a thought that occurred to me
.... if you have hidden folders set to show, go back and, temporarily, set
them to be hidden again. You didn't say which OS you are running ... so
don't know if you can even get to these settings. In Vista, go to Control
Panel --> Folder Options --> View tab.
Then, whichever folders you don't want to exist during the visit, right
click the folders, go to properties, then checkmark the hidden attribute
(down near the bottom of the general tab.) You could create a special folder
for this trick and move all your sensitive stuff to the new folder. Then
just hide that one.
After they are gone, go back to Folder Options and mark hidden stuff to show
again. Have no idea if this will work ... just a thought ... vanilla
"alikhan" <guest@xxxxxx-email.com> wrote in message
news:55718aa6d205f06b0a958852b7e67ac3@xxxxxx-gateway.com...
> hi
> thanks.
> alikhan
F
FromTheRafters
> hi
Probably.
Ask a better question, maybe a better answer will come.
Will setting a password in the CMOS setup program suffice?
Do you want them to be able to use the computer?
Do you have more than one account on your computer, or are you running
only as (protected) administrator all the time?
Will creating a limited account (4 ur cosins) suffice?
Are you actually using Vista, or did you just stumble into this group?
panais
Power User
323
    Custom Built by me.
    Intel Core 2 Quad Q6600
    Gigabyte GA-X38-DS4
    KINGSTON HYPERX DDR2 4GB (2X2GB) PC6400 800MHZ DUAL CHANNEL KIT
    SAPPHIRE RADEON HD4890 OC 1GB GDDR5
    2/4/5.1/7.1-channel Realtek High Definition
    Samsung LE40A656F1 1080p 100Hz LCD HD TV 50,000:1
    1366x768 in Desktop,1920x1080p in gaming and video
    C:\WD VelociRaptor 150 GB,10,000 RPM
    D:\WESTERN DIGITAL WD15EADS 1.5TB CAVIAR GREEN SATA2 E:\WESTERN DIGITAL WD15EADS 1.5TB CAVIAR GREEN SATA2 No Raid.Copy Paste Is The Safest Way.
    Seasonic 700W 80plus
    A-Case Twin Engine BB
    3 thermaltake smart case fan II + 1 arctic cooling fan
    Wirelles Logitech Laser Mouse MX620
    Wireless Logitech LX710
    ADSL 4000plus
    F:\Sony high speed sata Dvd Rewriter
    KINGSTON HYPER X FAN
    +Cordless Rumblepad 2
B
Bill Daggett
alikhan <guest@xxxxxx-email.com> wrote:
>this will gona help me
It will, if you don't want them even to be able to use your computer.
MAKE ABSOLUTELY SURE that you write the password down!
J
#8
On Wed, 5 Aug 2009 22:06:47 -0500, alikhan <guest@xxxxxx-email.com>
External usb drive , copy and send files to it . If ok , delete
original files .
R
Ray Luca
#9
>original files .
You're an idiot.
G
Gordon
#10
"Ray Luca" <rayluca@xxxxxx> wrote in message
news:kbfl75t01m4s5pk7lklv4la8u4eknqfoq8@xxxxxx
>>original files .
> You're an idiot.
Why so? if the files ONLY exist on a USB thumbdrive in the OP's pocket then
his cousins can't POSSIBLY open them under ANY circumstances short of
physical violence to extract the drive from the OP's pocket...
