Locked myself out of C drive
koksi894
Hey everyone, I'm really hoping for a miracle here and that someone can help me. I stupidly have denied myself access to the entire C drive. Was fiddling around w/ permissions to try to set up a guest account and clicked the "deny" buttons for the C drive, and now I can't access it all (this is using administrator account). I can't reset the priveleges, won't even allow me access to that.
I have spent the last two days trying to find a solution online but nothing works. Tried ERD commander but it doesn't work with vista. Have tried talking to my tech friends and even they can't figure it out. I can't access anything on C and cannot reset the permissions, even as an administrator.
Please, please help!!!
mansrm81
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Western Digital 160 GB IDE
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
SCSIraidGURU
Right click on C: drive, go to security, take ownership of the drive.
    16GB DDR667
    SAS RAID
koksi894
I can't access the hidden admin account because when I try to run command prompt it tells me access denied b/c it's on the C drive. I cannot access the ownership tab to take back permissions because it is also denied. I have tried both of these!
SCSIraidGURU
Enable your administrator account and reverse what you in security.
    16GB DDR667
    SAS RAID
koksi894
The account I'm on is an administrator account. I can't access the true administrator account because it denies me access when I try to run command prompt.
koksi894
I tried taking screenshots but I can't even do that b/c I can't save to the C drive and I don't have an external hard drive with me.
To sum:
1) Locked myself out of C drive by denying privileges
2) Cannot access the security tab to reset privileges b/c that also is denied
3) Cannot log on the "hidden" admin b/c access to command prompt is denied
4) Tried booting ERD commander but that doesn't work with Vista
Please help!!!!
mansrm81
If you can't do anything to fix your problem I'm afraid your going to have to reinstall vista.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
VistaLava
cant u use a live linux disk to access the drive, and either fix the permissions or burn the data you want to keep?
    HP dv6519tx
    160Gig
    Microsoft Trackball
    Depends on the neighbours wireless network
SCSIraidGURU
Can you activate your administrator account?
    16GB DDR667
    SAS RAID
koksi894
My normal account is an administrator account, but it won't let me change privileges. I can't access the hidden administrator account because command prompt is denied access. I *can* access it through safe mode, but when I try to unlock the administrator account it doesn't work (says it can't find it or something similar).
SCSIraidGURU
Can you create a new administrator level account? Do a repair install from the DVD.
    16GB DDR667
    SAS RAID
