Login "Password Incorrect"
Mharse
9
I am recently getting a "Incorrect Password" message when trying to login. I am administrator with a password. My husband (standard user with password) is having the same problem. In addition, a box with "Ease of Access" options pops up while I am in the middle of typing my password. This problem does not happen with my husband. The only way we can log in is to do so as our daughter first (She has no password), then "switch user." At this point, it will finally let us log in. Thanks for any ideas.
Brink
Staff member
mvp
32,206
Location
Oklahoma, USA
Hello Mharse, and welcome to Vista Forums.
Do you have the computer set to log on automatically to a user account. If so, then check to make sure that the password is correct by re-entering it.
If not, then you might see if changing the password for the account after you are able to log on to it may allow you to log on to normally again.
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
Dwarf
The Contemplator
2,760
Location
Doncaster, UK
Is the keyboard layout correct? For example, when you set up your PC, you used the En-US layout and subsequently changed it to the En-UK one. If that is the case, some of the key locations change.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
544
Location
Rhode Island
Mharse,
When you finally are able to log onto your profile, do a malware (virus is the more common term) scan with MalwareBytes. It is an extremly useful scanner. It sounds like you could be infected. There are always ways around infections and the switch user feature is the way you can get around it.
Yes, there may be no other warning signs that you are infected, but to me it sounds like you are....
Let us know,
Ben
    Dell
    Intel(R) Celeron(R) CPU 420 @1.60 GHz
    Dell Inspion 530 Default
    PNY 4GB 240-Pin SDRAM DDR2 800 (PC2 6400) Dual Channel
    ATI Radeon HD 2400 PRO
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Seagate 250G ATA SATA-II
    Dell Inspiron 530
    None
    Logitech EX100 Combo
    100 MB/s
Mharse
9
#8
Sorry, I don't understand the keyboard post. I have MalwareBytes and scan on a regular basis. I just did one now and it found nothing. Any other ideas?
Dwarf
The Contemplator
2,760
Location
Doncaster, UK
#9
Hi Mharse,
This is what I am referring to. Notice how the position of some characters are different according to the locale.
    Gigabyte IF233
544
Location
Rhode Island
#11
I dont think that this is a keyboard issue because there is still a way that she can correctly log in.
Mharse,
Do you have any system restore points available since before this started to happen?
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
17
Location
Burbs of Chi-town
#12
Try starting up in safe mode, hoping your account isn't the "administrator" account, when you get to safe mode, click on the "administrator" account, or even your account and try it, then try disabling the password then restart and try logging in again.
whs
2,026
Location
Germany/Florida
#14
It happened to me a few times too. Problem was that the numeric lock was on and some letters from the right side of the keyboard were entered as numbers. But since you cannot see what you enter with passwords, it took me a while to figure that one out.
    Dell
    Q6600
    HP w2207h
    2x250GB HDDs
    1x60GB OCZ SSD
    6 external disks 60 to 640GBs
Brink
Staff member
mvp
32,206
Location
Oklahoma, USA
#15
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
Mharse
9
#16
Thanks for the link to system restore instructions. I did the system restore, using a date before the problem started, but I am still getting the "incorrect password" message.
Brink
Staff member
mvp
32,206
Location
Oklahoma, USA
#17
Mharse,
You may need to use METHOD THREE to reset it then.
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
Mharse
9
#18
Brink,
I think I may have found the problem. I believe the password problem started right after I installed the driver for my Logitech webcam and used it for the first time. So I uninstalled it, and was able to log in to both my account and my husband's with no problem! Does this sound possible? Should I try re-installing it, or what next?
Brink
Staff member
mvp
32,206
Location
Oklahoma, USA
#19
Mharse,
I'm happy to hear that you found the source of the problem. Strange, I would not have thought that would have caused this. I would recommend that you create a restore point before trying to reinstall the webcam driver. This way you could easily do a system restore at boot using that restore point to easiy undo it if needed.
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
544
Location
Rhode Island
#20
Mharse,
So glad to hear that this was successful, and you found the problem. If i may suggest, go online to logitec and locate the driver for your webcam. Download it from there and install it that way. It could be updated or they could have fixed a problem that caused your problem to happen.
Let us know how everything goes,
Ben
Brink,
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
