loginscript.vbs in Vista
J
Joe Blow
We are testing .vbs for login scripting. 99% of our install base is XP, one
of my test users is on Vista. When logging in this morning, he received
this error, but later when I had him manually run the script, it worked with
no issue.
Script: \\domain.local\netlogon\loginscript.vbs
Line: 118
Char: 1
Error: The specified domain either does not exist or could not be
contacted.
Code: 8007054B
Source: (null)
Line 118 shows:
strUserDN = objSysInfo.userName
With a line prior in the script defining objSysInfo (Line 100):
Set objSysInfo = CreateObject("ADSystemInfo")
I can post more of the script if necessary, but the whole thing is over 500
lines so I don't want to do that unless I have to.
Thanks!
R
Richard Mueller [MVP]
"Joe Blow" <joe@xxxxxx> wrote in message
news:ufKn8xNcJHA.3948@xxxxxx
> one of my test users is on Vista. When logging in this morning, he
> received this error, but later when I had him manually run the script, it
> worked with no issue.
> Line: 118
> Char: 1
> contacted.
> Code: 8007054B
> Source: (null)
> Line 118 shows:
> 500 lines so I don't want to do that unless I have to.
> Thanks!
The behavior suggests the user logged in locally and not to the domain. Is
that possible? Or was the domain not available and he use cached
credentials?
Richard Mueller
MVP Directory Services
Hilltop Lab - http://www.rlmueller.net
J
Joe Blow
"Richard Mueller [MVP]" <rlmueller-nospam@xxxxxx> wrote in
message news:umFIdSOcJHA.1704@xxxxxx
> credentials?
> Richard Mueller
Definitely not logged locally, he said he logged in, got the error, I went
over to his box and showed him how to manually run the script and it worked
fine.
Seems like I read of a method to force the login script to wait until the
network is up/active prior to running. Does that ring a bell? I do have
the script assigned via GPO in AD.
R
news:eyTE1WOcJHA.1188@xxxxxx
>> Is that possible? Or was the domain not available and he use cached
>> credentials?
>> Richard Mueller
> worked fine.
A delay was required in Windows 95/98, but not since. By default logon
scripts run with a full user token (representing group memberships), even
though a limited token is used afterwards (due to UAC). I'm not sure if this
applies here (as no permissions are required to retrieve objSysInfo.userName
other than authenticated user), but here is a link discussing why drives
mapped in a logon script cannot be viewed and how to fix:
http://social.technet.microsoft.com.../thread/86a61bb4-ab90-405e-9adf-355e7245d632/
Basically, the logon script can map the drives but the user cannot view
them. Or the logon script prompts for permission and the user doesn't see
the prompt.
One fix is a *.wsf file that basically runs the logon script as a separate
task, so they run in what is called UAP mode. There's a good example in the
link. The other fix is a group policy setting, but I think it only applies
to Administrators. Let us know if this helps.
If you want to try a delay, simply insert the following in the VBScript:
Wscript.Sleep 1000
This pauses for 1000 milliseconds. I used to use 100 milliseconds in Win9x.
Richard Mueller
R
\RemS
> > credentials?
> > Richard Mueller
> fine.
You might have to turn off the Fast Logon Optimization feature in Vista?
By Enabling the following policy setting (GPO):
Computer Configuration\Administrative Templates\System\Logon\"Always wait
for the network at computer startup and logon"
(or manually,
Go to Registrykey:
HKEY_LOCAL_MACHINE\Software
\Policies\Microsoft\Windows NT
\CurrentVersion\Winlogon\
Edit the value:
SyncForegroundPolicy = 1 ("REG_DWORD")
Reboot the computer )
\Rems
