Logon script not working
B
Hi. I have made a logon.cmd file and put it in the Logon window in GPO. When
I manually run it, it adds the login information of the server. I can browse
to the logon.log file from clients and even run a command from the command
prompt:
echo "testing1" >> \\server\logons\logon.log and that works where server =
server name and logons is the share.
It seems the only thing that isn't happening is when a user logs on, it
isn't running the logon.cmd file in Group Policy.
Any suggestions?
A
Ace Fekay [MCT]
"Bert" <Bert@newsgroup> wrote in message
news:7B3AC2DF-91AF-405D-A33A-4E46D8278044@newsgroup
> When
> browse
> prompt:
> Any suggestions?
When you say you put the file in the logon window in GPO, do you mean that
you physically copied it into the physical location of the GPO after you
clicked on the Browse button? When you click on browse, it first puts you
into the GPO's location in Sysvol.
Normally an easy way to get a file into where logon scripts belong in a GPO,
is after you click on browse, go to another explorer window, go to the
location that your copy of logon.log (was that the name of it? - your UNC
example shows logon.log, not logon.cmd) or where logon.cmd exists,
right-click and copy it, then go back to the GPO logon file browse window,
and paste it in there, then once pasted, select it for your login script.
I assume there are no event log errors on the client side or the SBS side,
as well as that the client and SBS are only configured to only use the SBS'
IP as a DNS address (meaning there is no ISP's DNS, router as a DNS address,
or some external DNS server in their IP properties).
Ace
This posting is provided "AS-IS" with no warranties or guarantees and
confers no rights.
Please reply back to the newsgroup or forum for collaboration benefit among
responding engineers, and to help others benefit from your resolution.
Ace Fekay, MCT, MCTS Exchange, MCSE, MCSA 2003 & 2000, MCSA Messaging
Microsoft Certified Trainer
For urgent issues, please contact Microsoft PSS directly. Please check
http://support.microsoft.com for regional support phone numbers.
B
Thanks for the help:
One thing I read stated an easy way to put the .cmd file in GPO was to open
the Show Files and paste it there. I did this, and I should say it is in
there and when I click on Add and Browse, it is also there. I wasn't sure
where to keep the .cmd file and I figured it was actually physically located
in the GPO window, but maybe it isn't. At this time, it is in the same folder
as the logon.log.
This website shows that the actual log file should be located at
\\dc1\share where dc1 for me is server and share is logons
http://msmvps.com/blogs/richardwu/archive/2007/05/29/logging-user-logon-event.aspx
> > When
> > browse
> > prompt:
> > Any suggestions?
> Ace
> confers no rights.
A
Ace Fekay [MCT]
news:DAFAA871-7464-4279-B054-15345ACCB8C3@newsgroup
Ok, I see what you mean about the log. Thanks for clarifying that.
It appear that you pasted it in the right spot. I assume where you pasted
the logon.cmd file, it was in the following path (note: this is an example
and your GUID would be different):
C:\WINDOWS\SYSVOL\sysvol\domain.com\Policies\{BD0979BF-E009-4AE4-9BFC-5CC5D991FAB1}\User\Scripts\Logon
Where did you link the GPO to, in the OU where the users exist?
Can you post what's in the logon.cmd file, please?
Thanks,
Ace
> open
> located
> folder
> as the logon.log.
>> > When
>> > browse
>> > command
>> > prompt:
>> > server =
>> > Any suggestions?
>> that
>> GPO,
>> window,
>> side,
>> SBS'
>> address,
>> Ace
>> confers no rights.
>> among
B
My path for where the logon.cmd file is:
Inside the logon.cmd file is:
echo logon %username% %computername% %date% %time% >>
Again, when I type this at a command prompt from a client (echo "testing1"
>> \\server\logons\logon.log) without the parentheses, it works.
Also, running the logon.cmd does show the logon for the server. So, it seems
everything is set up correctly except a user logon is not triggering the
batch file.
Which brings me to your question: Where did you link the GPO to, in the OU
I think this is what I may have left out. I didn't link anything. I am not
sure where the organizational unit is or if I needed to make a new one.
Thanks.
> Thanks,
> Ace
> > open
> > located
> > folder
> > as the logon.log.
> >> > When
> >> > browse
> >> > command
> >> > prompt:
> >> > server =
> >> > Any suggestions?
> >> that
> >> GPO,
> >> window,
> >> side,
> >> SBS'
> >> address,
> >> Ace
> >> confers no rights.
> >> among
A
Ace Fekay [MCT]
news:6E93E0EA-0E79-4870-BE0A-40AAF4D86929@newsgroup
Before I get into OU structures and linking the GPO, if you copy the file to
the NETLOGON folder (C:\WINDOWS\SYSVOL\sysvol\domain.com\scripts), and
specify the file name in a test user's AD properties (profile tab, logon
script section), does it run when the test user logs on?
Ace
> seems
> batch file.
> Thanks.
>> example
>> Thanks,
>> Ace
>> > open
>> > in
>> > sure
>> > located
>> > folder
>> > as the logon.log.
>> >> > GPO.
>> >> > When
>> >> > can
>> >> > browse
>> >> > command
>> >> > prompt:
>> >> > server =
>> >> > it
>> >> > Any suggestions?
>> >> that
>> >> you
>> >> you
>> >> a
>> >> GPO,
>> >> UNC
>> >> window,
>> >> script.
>> >> side,
>> >> SBS'
>> >> address,
>> >> Ace
>> >> confers no rights.
>> >> among
B
Sorry, I had to get some sleep. I should have let you know. That works!
The only problem would be if I were running roaming profiles or some other
logon script, where would I put it? Luckily, I stopped using roaming
profiles, because it caused more problems than it was worth. Plus, I can't do
any logoff script.
But, for now, this is very good. Thanks.
> Ace
> > seems
> > batch file.
> > Thanks.
> >> example
> >> Thanks,
> >> Ace
> >> > open
> >> > in
> >> > sure
> >> > located
> >> > folder
> >> > as the logon.log.
> >> >> > GPO.
> >> >> > When
> >> >> > can
> >> >> > browse
> >> >> > command
> >> >> > prompt:
> >> >> > server =
> >> >> > it
> >> >> > Any suggestions?
> >> >> that
> >> >> you
> >> >> you
> >> >> a
> >> >> GPO,
> >> >> UNC
> >> >> window,
> >> >> script.
> >> >> side,
> >> >> SBS'
> >> >> address,
> >> >> Ace
> >> >> confers no rights.
> >> >> among
A
Ace Fekay [MCT]
#8
news:ABC7C166-9BD0-4C1F-8892-65D226644F4B@newsgroup
That's good to hear! So we know the script works.
Now tell us whether you created a new GPO or you altered an existing GPO for
the logon script.
If an existing GPO, what is it called?
If you created a new one, what did you call it, and exactly where is it? If
you can, take a screenshot of your GPMC, and post it somewhere where we can
take a peek at it.
Ace
> do
> any logoff script.
>> to
>> Ace
>> > "testing1"
>> > seems
>> > the
>> > batch file.
>> > OU
>> > not
>> > Thanks.
>> >> pasted
>> >> example
>> >> Thanks,
>> >> Ace
>> >> > to
>> >> > open
>> >> > is
>> >> > in
>> >> > sure
>> >> > located
>> >> > same
>> >> > folder
>> >> > as the logon.log.
>> >> >> > in
>> >> >> > GPO.
>> >> >> > When
>> >> >> > can
>> >> >> > browse
>> >> >> > the
>> >> >> > command
>> >> >> > prompt:
>> >> >> > server =
>> >> >> > on,
>> >> >> > it
>> >> >> > Any suggestions?
>> >> >> mean
>> >> >> that
>> >> >> after
>> >> >> you
>> >> >> puts
>> >> >> you
>> >> >> in
>> >> >> a
>> >> >> GPO,
>> >> >> the
>> >> >> your
>> >> >> UNC
>> >> >> window,
>> >> >> script.
>> >> >> SBS
>> >> >> side,
>> >> >> the
>> >> >> SBS'
>> >> >> address,
>> >> >> Ace
>> >> >> and
>> >> >> confers no rights.
>> >> >> benefit
>> >> >> among
>> >> >> resolution.
>> >> >> Messaging
>> >> >> check
B
#9
Thanks Ace,
I have to apologize. I am fairly stupid when it comes to GPO at this point.
I did exactly what you said to test it, and it works. I think once I found a
place to make GPOs, say if I wanted only three of my employees to be able to
do something or have rights. But, I can't find that. So, I think you will
need to be more specific, because I am not smart enough in SBS to figure out
your question.
Can I make Notify me of replies the default?
> the logon script.
> take a peek at it.
> Ace
> > do
> > any logoff script.
> >> to
> >> Ace
> >> > "testing1"
> >> > seems
> >> > the
> >> > batch file.
> >> > OU
> >> > not
> >> > Thanks.
> >> >> pasted
> >> >> example
> >> >> Thanks,
> >> >> Ace
> >> >> > to
> >> >> > open
> >> >> > is
> >> >> > in
> >> >> > sure
> >> >> > located
> >> >> > same
> >> >> > folder
> >> >> > as the logon.log.
> >> >> >> > in
> >> >> >> > GPO.
> >> >> >> > When
> >> >> >> > can
> >> >> >> > browse
> >> >> >> > the
> >> >> >> > command
> >> >> >> > prompt:
> >> >> >> > server =
> >> >> >> > on,
> >> >> >> > it
> >> >> >> > Any suggestions?
> >> >> >> mean
> >> >> >> that
> >> >> >> after
> >> >> >> you
> >> >> >> puts
> >> >> >> you
> >> >> >> in
> >> >> >> a
> >> >> >> GPO,
> >> >> >> the
> >> >> >> your
> >> >> >> UNC
> >> >> >> window,
> >> >> >> script.
> >> >> >> SBS
> >> >> >> side,
> >> >> >> the
> >> >> >> SBS'
> >> >> >> address,
> >> >> >> Ace
> >> >> >> and
> >> >> >> confers no rights.
> >> >> >> benefit
> >> >> >> among
> >> >> >> resolution.
> >> >> >> Messaging
> >> >> >> check
A
Ace Fekay [MCT]
#10
news:50A3DB65-8F77-4DB5-B150-0B043EA4A3C7@newsgroup
I'm not sure about making notifications default. I thought that was the
default when posting through the Microsoft web-based discussion forums. I
use a newsreader, so it's a little different.
You said you found a place to make a GPO. Where was that? What tool did you
use? Group Policy Management (Start-Administration Tools - Group Policy
Management)? That tool is also called the GPMC (Group Policy Management
Console).
My previous post I was saying to open the GPMC, and screenshot it. Before
screen capture, expand all the nodes (the plus + signs to see everything).
You can upload the pic to Microsoft's SkyDrive so we can see it.
SkyDrive - Windows LiveFree storage on Windows Live.
With SkyDrive, it's easy to store and share your files and photos with
almost anyone.
http://skydrive.live.com/
Also, maybe if you can provide a step-by-step of exactly what you did with
the GPO (from creation or altering an existing one), that will help
determine exactly what you did and where it is.
Ace
> Thanks Ace,
> point.
> a
> to
> out
> your question.
>> for
>> the logon script.
>> If
>> can
>> take a peek at it.
>> Ace
>> > other
>> > can't
>> > do
>> > any logoff script.
>> >> file
>> >> to
>> >> logon
>> >> Ace
>> >> > "testing1"
>> >> > it
>> >> > seems
>> >> > the
>> >> > batch file.
>> >> > the
>> >> > OU
>> >> > am
>> >> > not
>> >> > one.
>> >> > Thanks.
>> >> >> pasted
>> >> >> example
>> >> >> Thanks,
>> >> >> Ace
>> >> >> > was
>> >> >> > to
>> >> >> > open
>> >> >> > it
>> >> >> > is
>> >> >> > in
>> >> >> > wasn't
>> >> >> > sure
>> >> >> > physically
>> >> >> > located
>> >> >> > same
>> >> >> > folder
>> >> >> > as the logon.log.
>> >> >> >> > window
>> >> >> >> > in
>> >> >> >> > GPO.
>> >> >> >> > When
>> >> >> >> > server. I
>> >> >> >> > can
>> >> >> >> > browse
>> >> >> >> > the
>> >> >> >> > command
>> >> >> >> > prompt:
>> >> >> >> > where
>> >> >> >> > server =
>> >> >> >> > logs
>> >> >> >> > on,
>> >> >> >> > it
>> >> >> >> > Any suggestions?
>> >> >> >> mean
>> >> >> >> that
>> >> >> >> after
>> >> >> >> you
>> >> >> >> puts
>> >> >> >> you
>> >> >> >> belong
>> >> >> >> in
>> >> >> >> a
>> >> >> >> GPO,
>> >> >> >> to
>> >> >> >> the
>> >> >> >> your
>> >> >> >> UNC
>> >> >> >> exists,
>> >> >> >> browse
>> >> >> >> window,
>> >> >> >> login
>> >> >> >> script.
>> >> >> >> SBS
>> >> >> >> side,
>> >> >> >> use
>> >> >> >> the
>> >> >> >> SBS'
>> >> >> >> DNS
>> >> >> >> address,
>> >> >> >> Ace
>> >> >> >> guarantees
>> >> >> >> and
>> >> >> >> confers no rights.
>> >> >> >> benefit
>> >> >> >> among
>> >> >> >> resolution.
>> >> >> >> Messaging
>> >> >> >> check
